03-31-2023, 11:56 AM | #1 |
425hp409
6 Lug Wheel Question
Will late model 6 lug wheels fit on a 70 with original 6 lugs?
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
03-31-2023, 01:39 PM | #2 |
Re: 6 Lug Wheel Question
Late model 6 lug has a bore of around 80mm, I know the rear hub on my 69 GMC was bigger, didn't even try the front. 16x6.5 wheels, 14mm wheel studs. Would have to get 1/2 or 9/16 wheel studs. Those wheels are what I was trying to fit.
03-31-2023, 05:13 PM | #3 |
A friend gave me 4 aftermarket aluminum 8x16 rims off his '99 Suburban. The 6-lug at 5.5'' spacing was the same, but the setback was too shallow. The wheel bore accepted the Dana 44 hubs on my 4x4 K/1500 GMC Jimmy [K/5 type], but I had to buy 1.25'' wheel spacers to mount the new-to-me rims with 235/75/R16 tires.
A weird noise on the freeway, got me to pull those wheels and spacers -- thinking something internal was coming loose. Even though Discount Tire had used 3 different sized lugnuts to mount the tires -- that wasn't the real problem. My front prop shaft was disintegrating. I had given them 25 all new gold anodized lugnuts, but they were too fat for the recessed holes in the fancy aluminum rims. So now my fancy lugnuts are holding my old 33x12.50x15 meat tires on at a proper 90 foot pounds.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 04-15-2023 at 12:48 PM. |
04-12-2023, 10:01 PM | #4 |
425hp409
ttt
04-13-2023, 12:38 AM | #5 | |
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
04-14-2023, 03:20 PM | #6 |
425hp409
With respect to the previous posters, your answers are not on topic. a 70 C10 2wd is what I need wheels for.
04-14-2023, 03:41 PM | #7 |
so any wheels designed for gm larger 6 lug after 1999 will not seat on our hubs, you have to use a spacer..
1967custom |
04-19-2023, 06:55 PM | #8 |
425hp409
So then I would have to install longer lug studs?
