Old 04-03-2023, 10:32 PM   #1
networx2002
c10 66 breaklights
Hello
1966 c10
I'm looking for some assistance here. I cant seem to get my tail lights to work.. When I turn the headlights on both tail lights work, but the brake lights don't on either side. The drive side was working then stopped and now neither side work. Not sure what the issue could be, so if you have any suggestions please let me know.
networx2002 is offline   Reply With Quote
Old 04-03-2023, 10:44 PM   #2
Arne
Arne's Avatar
Re: c10 66 breaklights
Brake light circuit goes through the turn signal switch. Do either of the turn signals work in back?
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 04-03-2023, 10:44 PM   #3
SkinnyG
SkinnyG's Avatar
When things are intermittent with electrical, it's usually a connection issue (power OR ground).
When things are possessed by the Devil, it's usually a grounding issue (something is grounding through a different circuit).
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 04-03-2023, 10:49 PM   #4
networx2002
I just bought the truck and it doesn't have turn signals. The driver side brake was working but the passenger side was never working. I know my dad was messing with the turn signals in the truck, maybe that caused the one brake light to go out. I'll mess around the turn signals this weekend and see if that does anything.
Old 04-04-2023, 09:03 AM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
Just asking.. Did you check the bulbs? Sometimes they can look good but not work.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-04-2023, 12:06 PM   #6
Southcity
Southcity's Avatar
Per your post, it's just the brake lights that are not working. Helpful to have second person to assist you while you test.
1.Double check the bulbs, if you have known good spares, swap them out to verify it's NOT the bulbs
2.There is a brake light switch on the brake pedal lever (up under the dash) check to ensure it is engaging properly, there is adjustment built into that switch. If you have a known good spare, swap them out to verify the switch is not the issue
3.Per user Arne, verify that your turn signals are/are not working
4.Do a visual on the tail light housing, socket and wiring. You need a good ground at the housing for the taillights/brake lights to function properly. Sometimes it's a loose socket, wire or bad ground.
Keep us posted once you have had a chance to check per the suggestions from members in this thread.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 04-04-2023, 10:37 PM   #7
networx2002
the 1st thing i did was replace the bulb...
My dad was thinking it might be the brake light switch, i have to take a look this weekend. Thanks for the feedback.
Old 04-05-2023, 11:36 AM   #8
Southcity
Southcity's Avatar
Great! keep at it and you'll get it figured out. The members in this forum are a great resource for help along the way.
Old 04-06-2023, 05:06 PM   #9
jayoldschool
Moderator
I've posted this before, but here's how I got my brake lights to work properly:
- removed the lenses, removed the buckets
- added a ground from bucket to bed
- added a ground from bed to frame at back
- added a ground from bed to frame at front of bed
- added a ground from back of cab to frame
- added a ground from front of bed to cab
Brake lights work perfectly now. Before, one worked dimly, and one only had "lights on", no brake illumination.
jayoldschool is offline   Reply With Quote
Old 04-08-2023, 01:56 AM   #10
networx2002
That's a lot of grounds... Would the tail light work and no brake lights if it was a ground issue?
Old 04-08-2023, 10:41 AM   #11
Southcity
Southcity's Avatar
Yes, a dirty ground, bad ground can result in having running lights (and most likely dim at that) and no brake lights. The bulb socket grounds itself to the housing which then has a ground wire to frame or body or both. It's important to make sure the bulb socket is tight and secure in the housing, if it's loose (turns freely), it will result in intermittent issues as well. Be sure to check all these things on both tail lights. Clean your ground surfaces really well if they are already in place.
Old 04-14-2023, 04:02 AM   #12
networx2002
Thank for the feedback. Wont get a chance till next week, but ill keep you guys updated.
Old 05-07-2023, 03:16 PM   #13
networx2002
Ok so I finally got time to mess with my brake lights. It looks like the issue is with the Taillight Pigtail connector. I'm now just going to upgrade to LED tail lights. My question is what led tail lights do you guys recommend?
Also I noticed I have 3 wires running to the brake light but all the LED lights only have 2...
Old 05-08-2023, 03:42 AM   #14
Agv63
I went led with mine.
United pacific is what i used. There is 3 wires coming from module but still has a 1157 male connector to fit the oe socket.
Since mine never came with the original wiring i did my own wires and used 3 pin deutch connector and did earth directly to frame .
Pic is brake lights on. Nice and bright.
Cheers.
Adriaan.
Agv63 is offline   Reply With Quote
Old 05-08-2023, 11:10 AM   #15
bigmoe
bigmoe's Avatar
I used these. (Sorry it's just the package) Simply plug in place of the old ones. No wiring, no mods.
bigmoe is offline   Reply With Quote
Old 05-08-2023, 12:24 PM   #16
Arne
Arne's Avatar
A couple notes: Make sure you get red LED bulbs, not white. (White through a red lens will be rather dim.) And note that you may need to replace the signal flasher relay to an electronic unit if the signals flash very fast.
- Arne
覧覧覧覧覧覧
1966 c10, brake lights
