04-04-2023, 05:53 PM | #1 |
Engine compartment wire routing
For you guys who have installed a new wiring harness, I'd like to see photos of how you routed the wires for:
brake warning switch (on combo valve) oil pressure sender coolant temp sender HEI power HEI tach electric choke starter solenoid I'm using the plastic "gutter" on top of the firewall, but can't decide where to drop down the wires. Thanks.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
04-04-2023, 06:09 PM | #2 |
Re: Engine compartment wire routing
Here's what I did. From left to right in the picture, the drops are: Starter solenoid, front engine harness - goes all the way to the temp sensor), HEI and oil pressure (I converted to electric), everything else. Since the brake warning wire kind of hangs out by itself, I used a couple of zip ties to attach it to the speedo cable.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
04-04-2023, 07:32 PM | #3 |
Mike, when I installed my AAW Classic Update kit, I dropped the brake sensor wire (tan) through the slot above the MC, I dropped the oil pressure sender wire, ignition, tach, and a ground wire (black wrap) down above my LH head, and then I ran the starter wire (purple) out the end of the gutter. My electric choke is powered by a jumper wire from the coil.
I later figured out the factory routing is to run all of them except the brake sensor out the end of the gutter (IIRC) and I wish I had done that. My "when I get around to it" list includes lengthening and re-routing those wires. I've stuffed some washer hoses in the gutter, too, but maybe they'll have to get booted in favor of the wiring.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
04-04-2023, 07:33 PM | #4 | |
My truck still has a bell crank and throttle rod, so I'm not sure what I'll run on that side. The linkage gets in the way of everything, including plug wires. What kind of sleeving did you use? Looks nice. I also like what you've done with the washer pump hoses. Mine are just flopping around right now.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 04-04-2023 at 07:38 PM. |
04-04-2023, 07:35 PM | #5 | |
Very nice job on the wiring!
04-04-2023, 07:46 PM | #6 |
I'm eliminating the wiring gutters completely, I just don't like the look.
I have put holes in the core support so that all the wires will be routed up underneath. I will extend the wires to the starter, temp sensor, and oil pressure all the way around to the back. Since I'm doing the LS1 swap, with all the wires associated with the engine harness, I want it all to look neat and clean..(hopefully) I drilled a 3/8" pilot hole and worked in a Greenlee chassis punch to make a hole 1-1/8" thru the core support.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
04-04-2023, 08:05 PM | #7 | |
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
04-04-2023, 08:36 PM | #8 | |
I just ordered some 3M tape that fuses to itself and won't unravel like regular electrical tape, so we'll see how that works.
04-04-2023, 08:44 PM | #9 | |
If mine was apart like yours, it would be a lot easier to do the wiring. I'm 6' 2" tall and still have a hard time reaching the middle of the firewall. I wired a friend's 37 Chevy several years ago before its fenders and "doghouse" had been installed. That was easy peezy.
04-05-2023, 09:48 AM | #10 | |
04-05-2023, 04:23 PM | #11 | ||
When I got the truck the EVAP vacuum lines and PCV hose were just randomly strung across the engine bay so I just ran new vac hose to clean up the engine bay to clean up everything BTW, if using split loom, don't use that stuff you get at auto part stores. Its not meant for engine bay (heat). Grey stripe is heat resistant and blue is flame resistant. I buy 100' rolls in various sizes in both grey and blue stripe and use it on many wire clean up or additions on all my hobby cars. Its fairly cheap from online sources |
04-05-2023, 04:44 PM | #12 |
On my 69 C10 project I used a generic Painless 21 circuit wiring and tried to hide as many wires as I could. The front headlight harness I ran down the left frame rail and then inside the upper radiator support. I didn't have washer hoses to deal with. Other wires routed behind the engine out of site.
I too would only use the braided wire covering. I get it from Summit. |
04-06-2023, 11:15 PM | #13 |
Funny, but that's actually what I ordered! I can't remember if the memory is the first or second thing to go!
That stuff is really nice. I did some experimenting today and the adhesive seems to "stay stuck" even after I hit it with a heat gun. The standard electrical tape, even 3M, gets all gooey, starts to come loose, and leaves a big mess if you ever have to remove it, even if you use it in a cool place, like under the dash.
04-07-2023, 01:19 AM | #14 |
I'm doing the same thing currently, deciding where each of these wires will go. I have smoothed my firewall and eliminated the wiring gutter as well so I suppose I'll need to lengthen some of the wires and find creative ways to keep them out of sight. Thanks to those who have added pictures of engine bay wiring.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
04-07-2023, 09:49 AM | #15 | |
04-07-2023, 12:11 PM | #16 | |
If you end up having to buy lengths of wire, be sure to use wire designed for high temps, which are rated TXL, GXL, and/or SXL. Their "cross linked" insulation also resists abrasion. There are lots of good sources for them in various lengths.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 04-08-2023 at 09:46 AM. |
04-07-2023, 06:48 PM | #17 | |
04-08-2023, 05:52 PM | #18 |
Making progress. Decided to run the engine wires all the way to the passenger side, then across the manifold behind the carb.
