04-08-2023, 01:38 PM | #1 |
Junior Member
Brake drum removal
I have a problem in that the front brakes need adjusted as even once bled I can still turn the wheel by hand. Main issue I have is the spacers are holding the drums on but I cant get them loosened off due to the wheel spinning when I try and loosen them?? I'm stuck lol
04-08-2023, 02:02 PM | #2 |
Re: Brake drum removal
You could drill 2 holes in a piece of long flat metal to act as a lever.
Bolt it to 2 of the studs the spindle then swap them around till you get them all broke loose. Or if you have a hardware store close that carry's some Unistrut like the link below it might work also. link: https://www.amazon.com/Genuine-Unist...99077813&psc=1
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
04-08-2023, 02:18 PM | #3 |
Wood 2x2 between the studs contacting ground.
04-08-2023, 02:29 PM | #4 |
Use an impact. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
04-08-2023, 03:31 PM | #5 |
Junior Member
Thanks guys
04-09-2023, 12:43 PM | #6 |
Junior Member
Any more ideas to get these spacers off? Ive tried heat and leverage and theyre not budging. Ordered an impact driver so just hoping that does the trick if no other ideas
Cheers Last edited by Belsh; 04-09-2023 at 12:45 PM. Reason: add photo |
04-09-2023, 12:51 PM | #7 |
Spray them with Kroil, pbblaster or your Favorite rust-buster.
Or a 50/50 Mixture of acetone and Transmission fluid. (By itself, transmission fluid isn’t strong enough to remove rust. However, when mixed in a 50/50 solution of acetone, it becomes a very powerful rust remover. Acetone is the secret ingredient most people aren’t aware of. If you are dealing with rust on your car, and have some used transmission fluid in your garage.) Maybe the impact will bust them after you soak them with one of the aboved mentioned.
04-09-2023, 01:19 PM | #8 | |
Junior Member
04-09-2023, 03:30 PM | #9 |
Someone probably used loctite on them. You may need heat the lug bolts up before you use the long breaker bar or ratchet
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 04-09-2023 at 04:19 PM. |
04-09-2023, 05:39 PM | #10 |
Post Whore
I know this is a long shot but did you try turning them the wrong way? Maybe someone installed some Mopar studs and they are left hand threads. It's a sure fire way to stop wheel thieves.
That being said I agree with Palf70Step about Loctite being a real possibility.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-10-2023, 12:59 AM | #11 | |
04-10-2023, 06:22 AM | #12 | |
It really works
