04-09-2023, 01:31 AM | #1 |
Screw for Turn Signal Lever
I lost the little screw that holds the selector lever on the T/S Switch cam inside the steering column.
I'm tired of making Hand Signals. What size is that screw?
04-09-2023, 10:32 AM | #2 |
Re: Screw for Turn Signal Lever
Well
I took the one out of a column I purchased here on the Board. I found a tap and a nut that that tap goes in, Just to double check it because over the years all kinds of stuff could happen. If this screw is original (It appears to be), It is a Pan head #8-32 and is 0.710" long and is self-starting. Hope this helps.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
