OEM window regulator
does this look right 1 roller facing the wrong way
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Re: OEM window regulator
Yes that is the way they are. The 2 facing the same way go into the glass Chanel and the single goes into the Chanel welded to the door.
Thanks for your speedy response
Really enjoy your build thread, great stuff going on there
Not seeing any welded track for the third roller
![]() ![]() Any help?
![]() Join Date: Nov 2013
It's INSIDE the door on the inner side right above the opening
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
Herea a picture of my door after I removed the door skin. It's circled.
Thanks guys for the help
Apparently repop doors didn't come with that Now I have to find someone willing to cut up a door for that channel This place is invaluable, we should charge for stupid questions
I bought repop doors for my 67 build...they have the channel in there...
![]() Join Date: Feb 2009
That's not a dumb question at all, you should see some of mine, wowza. Can't believe they didn't install that. They even mark where they go? It has to be exactly right. Lub that channel up once there, and don't forget the rubber bumpers for the roll ups. Hopefully they installed window platforms, yikes.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Dec 1999
Look at the area I circled, see the spot welds? Right behind there. Sorry about pic quality, had to take a snip of your photo as I could not download it. If it is not there it fell off as it was put in otherwise the spot welds would not be there.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
OK, I'm an idiot
Even with the prompting of location and pictures I was looking in the wrong location, I am going to call this a senior moment and wave my old folks card Richard hit the nail on the head when he saw the spot welds, and there it WAS Thanks for all help from use guys, disaster Averted
![]() I like to assemble hex drive set screws Cross threading drives me nuts, well more so..... None OEM window crank handle
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-24-2023 at 09:52 AM. |
