04-19-2023, 07:23 PM | #1 |
68 C10 Longbed
Muncie shift lever
Not sure but I’m thinking of putting threadlock (Not Red) on the bolt that holds the 3rd &4th shift lever in place on my M22. The bolt keeps loosening which keeps it from going into 3rd & 4th. It has a lock washer. Sound like a good idea?
Shifts perfectly with the bolt tight. Last edited by ghackett1; 04-22-2023 at 07:01 AM. |
04-19-2023, 09:43 PM | #2 |
Senior Moment
Re: Muncie shift lever
Shouldn’t be a problem, the nut on my Sons Muncie are locking nuts
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
04-20-2023, 03:37 AM | #3 |
68 C10 Longbed
04-20-2023, 09:25 AM | #4 |
I did some low level road racing. The green penitrating Loctite worked really well on bolts I want to remove easily. Some of the bolts were often loose after a weekend but once I stated using green, I never had a problem.
Drilling the bolt head and using safety wire was also an option if I had a point to anchor from. |
04-20-2023, 10:53 AM | #5 |
When I had my M-22 rebuilt I used the Muncie tapes information / parts from Paul at 5speeds.com . His billet shift dogs / hardened bushings and linkage clips really tighten up the action . The guy wrote the book on Muncie transmissions .
https://www.5speeds.com/cart/index.p...product_id=105 start this video at 8:10 for info on the shift dogs / cover upgrades . https://www.youtube.com/watch?v=zqeatqmnW0c
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
04-20-2023, 02:54 PM | #6 | |
68 C10 Longbed
04-20-2023, 02:55 PM | #7 | |
68 C10 Longbed
