Old 04-21-2023, 01:24 PM   #1
snowball
Bad new ICM?
Hi all,
My truck died 6 months ago and I was too busy to fix it. turned out it was the Ignition Control Module. No fire, no fuel.
I replaced with with a GM original. now she is ROUGH! Hard to start. Idles rough. Backfires. Hesitates.
I put in fresh fuel. Same problem.
Bad ICM or should I look at something else?
Yes. I did put the thermal paste on the new ICM.
1990 350 R1500
1990 suburban r1500 k 350 2wd
snowball is offline   Reply With Quote
Old 04-23-2023, 04:07 AM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Bad new ICM?
Did you reset timing? Perhaps something changed there.
Old 04-24-2023, 06:20 PM   #3
snowball
Re: Bad new ICM?
I did not.
I need to get a new one. Last one broke. any recommendations?
Old 04-26-2023, 01:05 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
Re: Bad new ICM?
Originally Posted by snowball View Post
I did not.
You mean your timing light broke? Any brand is fine I’m sure. I like the ones that can advance in degrees to check total timing.
Old 04-26-2023, 05:39 PM   #5
chris989
Re: Bad new ICM?
Hi all,
1990 350 R1500
I went through a hand full of modules inside the distributor. most are chinese junk with little or no heat sink.
Now i keep an extra in my glove box
chris989 is offline   Reply With Quote
