04-22-2023, 08:08 PM | #1 |
72 C-10 Help
Evening Guys I need some help here I'm rebuilding my front end on my C-10 I've replaced my Upper and lower control Arm bushings I'm looking in the shop manual here but I'm not getting the torque specs for the bushings can some one explain how much to torque them Thanks appreciate it
04-23-2023, 01:52 AM | #2 |
Re: 72 C-10 Help
It appears that there is a misprint in your manual. Here's that same section from the 1968 service manual.
Upper Bushings, 160 new, 95 used Lower Bushings, 280 new, 135 (130) used (ft-lbs) |
04-23-2023, 11:09 AM | #3 |
Re: 72 C-10 Help
Thank you Sir appreciate it
04-23-2023, 04:23 PM | #4 |
Re: 72 C-10 Help
I haven't had to do this yet, but there are quite a few threads where the torque specs don't necessarily match the actual effort to seat these things. Prolly worth reading a few for context.
04-23-2023, 07:20 PM | #5 |
Who Changed This?
Re: 72 C-10 Help
Indeed. When I rebuilt the front end on my truck, the running torque on the lower control arm shaft nuts was above the "replace" torque spec. I ran them down until the torque went up, and left them at that. Nothing has backed off in the last 8 years.
04-23-2023, 09:51 PM | #6 |
Re: 72 C-10 Help
Thanks for the help guys I've been thinking reading alot of threads one more ? what are the dimples for on the lower control are shaft Thanks again Great site
04-23-2023, 10:49 PM | #7 |
Re: 72 C-10 Help
04-23-2023, 10:52 PM | #8 |
Re: 72 C-10 Help
The dimples are to locate the shaft on the truck. Look under the seat that the shaft sets in. You will see a dowel in one of them. The dowel must go in the dimple. Be shure & position the dimple on the correct side of the control arm.
George |
04-23-2023, 11:09 PM | #9 |
Re: 72 C-10 Help
Awesome Sir Thanks so much for all the response I've learned alot from site appreciate it
