04-23-2023, 08:50 AM | #1 |
Tailgate Locking cylinder + key hardly needed
Hi all,
I'm Marco from Berlin, Germany. I cannot remember the last Post post I set here. It must been a lang time ago. I own a 84' Suburban since 25 years, I restored 10 years ago. For some reason, which I cannot explain, my original locking cylinder for my power window/tailgate was stuck at some time years ago. It means, the small pins in there were something like glued. I tried all to get it working again. But all failed. So, now I am hardly searching for a replacement part. Of course I would need at least one working key with it. Does anybody know a supplier, ob something else, where I could get a working Locking cylinder? LMC, etc doesn't offer that part, I think.. I hope somebody has an idea, or an old one in stock, which I could buy. So, I hope for help.. Greetings Marco |
04-23-2023, 08:54 AM | #2 |
Re: Tailgate Locking cylinder + key hardly needed
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
04-23-2023, 03:51 PM | #3 |
Hey!
Thanks a lot for your quick answer!! I checked that link, but obviously and unfortunately it is for the "manual" version, and not for the "powered" version, live mine is. I will check that site further. Maybe, I have luck to find my searched version, too? |
04-23-2023, 09:22 PM | #4 |
Your Welcome.
Here is another To The top. Lockdoc may know of a solution to your issue.
04-24-2023, 09:42 PM | #5 |
Junior Member
Good Evening ... See if this will work for you ... I think I remember finding the Tailgate Only cylinder that controls the window ... I will keep looking
SETS: https://www.motorcityk5.com/i-13513-...=category:9289 https://www.jegs.com/i/JEGS/555/1808...RoCrtsQAvD_BwE SINGLE: https://www.motorcityk5.com/i-13243-...91-blazer.html https://www.summitracing.com/parts/p...BoC-z4QAvD_BwE I also found where a person can purchase the electrical tip to this but if your tumblers are jammed up the then the entire piece is needed. Last edited by rwjtexas; 04-24-2023 at 10:27 PM. |
04-29-2023, 06:56 AM | #6 |
Hey!
04-29-2023, 07:07 AM | #7 | |
Thanks a lot for that help and links!! How could I overlooked those offers? I will check that out, and order some soon. Yes, I think I have to Look for that tip/linkage at the end of the lock cylinder.. Maybe I can find, with some luck, a spare part in my spare-cable-box.. Man, I'm lucky to have the chance to complete my tailgate, finally! |
04-29-2023, 07:09 AM | #8 | |
04-29-2023, 07:29 AM | #9 |
I just ordered that one offered at summit.
Now, I have to look for the switch pinned to the lock cylinder.. |
04-29-2023, 07:31 AM | #10 | |
04-29-2023, 07:11 PM | #11 | |
Junior Member
Send a picture of exactly what you are looking for and I can try to look it up on some sites. The Tail Gate Lock Cylinder you are buying has the electrical tip that controls the raise and lower of the glass is on it. |
04-29-2023, 10:42 PM | #12 | |
Just click on Edit then Delete. Hope you get the lock you are looking for. This double post happens every once in a while.
