04-26-2023, 05:23 PM | #1 |
Help! I can't install the starter, it hits the flexplate
Back story, I'm converting from 4spd to automatic. I've got a Targetmaster 350, 2 piece rear main seal.
I bought a new mini starter (Amazon China) that is supposed to fit 154 or 168 teeth flexplate. I bought ATP Z-111 flexplate, suppose to be for the 2 piece rear main seal yet have 168 teeth. As you can see by the picture, I hit the flexplate before I can even get the second bolt in. And I already installed the shims to move the gear drive back. Is this just a problem with this type of mini starter? Do I have a bad flexplate? Should I shim the flexplate? Need advice guys. |
04-26-2023, 05:43 PM | #2 |
425hp409
Re: Help! I can't install the starter, it hits the flexplate
Do not shim the flexplate. Have you tried the starter that was with the manual trans? The starter will either fit or it wont, no maneuvering needed.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
04-26-2023, 05:50 PM | #3 |
I can't use the old starter, that one bolts to the trans, I need one to bolt to the block
04-26-2023, 06:19 PM | #4 |
I think I might have found the problem. Compare the two pics. The one with the blue background is the starter I bought from Amazon. And in the other pic, is a starter of the same design but from Summit. See how much further my gear is protruding from the block compared to the Summit one. I need to put a BIG shim on the block and move the starter back more.
Think this is it? |
04-26-2023, 07:11 PM | #5 |
Looks like it might be in the wrong mounting hole. Try the other hole that will move it away from the block/bellhousing.
04-26-2023, 09:39 PM | #6 |
Make sure you have the right starter for your (engine yr/flex plate config).
Be careful not to overtighten those bolts too. no impact tool. I just went thru 4 starters trying to get them to work past 1-2 months before it would start whining cause teeth would start not line up with flexplate anylonger. turns out, the engine block has a hairline crack and would cause the starter to shift after a few weeks. PIA trying to find someone to weld cast iron too.. I ended up buying a Powermaster XS Torque Starters 9526 which i'm able to use three bolts for now. Good luck.. |
04-26-2023, 09:57 PM | #7 |
Install the inner bolt first , Just looking at your picture it's mis aligned .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
04-26-2023, 10:32 PM | #8 | |
04-26-2023, 11:30 PM | #9 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Here's the starter that works, see those holes in a radius? They allow you to clock the gear in or out from the flexplate. Your pic is vague I can't make nothing from it. You may need to clock (rotate) the starter motor on the aluminum mounting plate to gain the correct clearance. What does the front of your starter look like? Some of these mini's dont allow adjustment. Do Not shim the flexplate! Only use shims to fine tune the final .025" of clearance. A paper clip is a good wire gauge to set the proper clearance at the gear teeth. Once you clock the starter and figure which holes to use, you can activate the bendix gear to measure tooth clearance with the clip. Unhook the main power (if you have it connected) and use a jumper wire to the solenoid S terminal to engage the bendix gear. Better pics, and a pic of the front of the starter will be helpful. Or a link to the starter you have? "Cheers" Oops, forgot this, https://www.jegs.com/i/JEGS/555/10012/10002/-1
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
04-27-2023, 12:12 AM | #10 |
Well, it's not a miss-alignment, I physically can't get both bolts in because the gears hit the flexplate. My starter looks exactly like that Jegs one by the way. I did play around and used some washers as a temporary shim. This moved the gear from the starter .22" back. Starter bolted up just fine, and when I kicked the gear out, the alignment looked really good too. So it looks like a China made issue, and I need to custom make a 1/4 inch shim to "correct" the starter.
Note, I would return it, but I'm past Amazon's return window. So instead of being out $90, I'm going to try and make a shim. |
04-27-2023, 03:52 PM | #11 |
Just as a double check. Where the starter bolts to, center of those holes to the teeth on my flexplate is .75". Is this normal?
04-27-2023, 05:00 PM | #12 |
I also found this post:
http://67-72chevytrucks.com/vboard/s...d.php?t=636586 In #12, it says the distance between the back of the block to the teeth should be .470-.477. I measured mine and it's .297-.300 What gives? Correct part number for the flexplate, and installed with the bumps facing out towards the tranny. Defective flexplate maybe? Can someone do some measurements so I can double check everything. |
04-27-2023, 05:09 PM | #13 |
If it was me, I would order this shim kit. Use the 3 hole shims to back the starter gear up and this will give you the clearance you will need.
https://www.speedwaymotors.com/Chevy...xoCbGEQAvD_BwE Also don't use the starter bolts in this shim kit since they are knurled starter bolts. |
04-27-2023, 05:22 PM | #14 |
Thanks Robo, but after looking at that other thread, it got me thinking. So I pulled up the reviews on the flexplate I bought from Amazon, and one guy commented that the center was bent almost 1/4" causing the starter to hit it.
My exact problem! So I'm ordering a Pioneer flexplate this time and go from there. I just may have to still do some shims, so who knows. And thanks again for the link. |
04-27-2023, 05:26 PM | #15 |
Post Whore
It's not a apples to apples as far as the exact same starter but, here is a link to how my switch to a late model GM starter went. I think you may have the same problem I did. You may find you need to shim your starter too.
Scroll down to post 461 and continue. http://67-72chevytrucks.com/vboard/s...698377&page=19 I will add that I've never had anything but heartache and misery from cheap starters.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 04-28-2023 at 04:08 PM. |
04-28-2023, 12:08 PM | #16 |
Make sure flex plate is not installed backwards. Flex plate should have a beveled edge in the center and should be visible as to the correct way it needs to be installed.
Not sure if it's possible or not with your flex plate but I have seen this problem before. I have used Pioneer flex plates, nice products. Bob |
04-30-2023, 06:23 PM | #17 |
Update:
I installed a Pioneer flexplate, FRA100, and now my block to ring gear is .38, still not the .47, but better. So now since I only need about .10, I'm going to order the shim kit from Speedway and give that a go. |
