04-28-2023, 01:28 PM | #1 |
Aluminum coolant over flow tank.
Does anyone with an LS swap recommend something nicer than the original plastic OEM one from a 2002 Silverado?
09-28-2023, 01:39 PM | #2 |
Re: Aluminum coolant over flow tank.
I'm not an 'LS swap guy' and maybe you've already decided what to do. But since nobody has answered, I'd do a search for LS swapped projects and just see what they did for coolant overflow. Most of my new product information comes from reading about projects. That said, what I've seen often is the long aluminum tube bottles mounted on the core support next to the radiator.
10-14-2023, 11:26 PM | #3 |
BMW & ASE Master Certified
I too haven't found a real nice oem looking solution either .. Maybe others that have found something will post pictures of their setups.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
10-30-2023, 10:15 AM | #4 |
Not sure if you've found something yet? I used a tank I found on eBay. $35
10-30-2023, 11:44 AM | #5 | |
two totally different things
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 |
