Old 04-29-2023, 11:26 AM   #1
jacko241
jacko241's Avatar
1971 GMC K15 4x4 radiator
Hello all, sorta new to the forum but have lurked for a while. Does anyone have any experience with the aluminum radiators like you can find on Ebay and Rock Auto?
jacko241 is offline   Reply With Quote
Old 04-29-2023, 01:27 PM   #2
D.B
Re: 1971 GMC K15 4x4 radiator
Welcome to the forum. I am sure there are a few on here that have installed aluminum radiators. I tried a Champion radiator but it did not work in the Texas heat with the AC on. So I had a custom radiator built by Wizard Cooling. Pricey but well worth it so far.
D.B is offline   Reply With Quote
Old 04-29-2023, 02:13 PM   #3
jacko241
jacko241's Avatar
Thank you!
Old 04-29-2023, 02:28 PM   #4
52napco
They suck...have yours repaired or buy a copper brass reproduction
From Summit or a Dewitts Made in USA
52napco is offline   Reply With Quote
Old 04-29-2023, 02:31 PM   #5
jacko241
jacko241's Avatar
Thanks for your candidness.
Old 04-29-2023, 04:06 PM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
No and I'm not interested in going aluminum. I would have to start buying orange antifreeze, not the Prestone or Peak I'm used to.
I have a '71 GMC Jimmy K/1500 w/ V8 350,
My 4-tier core copper/brass radiator is in the shop, as we speak. Estimated cost for rebuild, re-rodding: $250. But I know it fits.
OBTW, nice Stepside.
Old 04-29-2023, 04:20 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
A few years ago my non-oem 4-row brass/copper radiator developed a few small leaks. I read up on aluminum ones and asked around, kinda like you are doing now. I don't recall all the pros & cons, but after talking with a guy at a radiator shop, I decided to have mine repaired. I'm still happy with my decision.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-29-2023, 05:55 PM   #8
tutone
tutone's Avatar
Champion let me down. I would buy oem next time and probably will anyway myself.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71
tutone is offline   Reply With Quote
Old 04-29-2023, 08:02 PM   #9
Ironhorse
Ironhorse's Avatar
I had my 4 row Harrison repaired for my 71 4x4 and has worked well since. Had the 4 row Harrison re-cored for my 71 Chevelle, pricey but rock solid at 190 degrees in Kansas heat and the Vintage Air cooling well. Had the original Harrison repaired in my 57 2 dr sedan and it stays rock solid at 180 in Kansas heat. I'm a big fan of and nothing fits and works like original GM parts.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 04-30-2023, 09:57 AM   #10
jacko241
jacko241's Avatar
Thanks all, I may just repair the original.
Old 04-30-2023, 10:34 AM   #11
Yamariv
Yamariv's Avatar
I'd repair the original for sure that way you know it's a perfect fit and it's made to last. I just upgraded my rad to a 3 Core Original. Had it cleaned and pressure tested and I'm good to go.
1971 Chev C10 - 250ci L6 w/3 speed on the floor
Upgrades: Power Steering
3 Core Radiator
7 Hole Gauge Cluster
Power Brakes (Incoming!!..)
1971 350 (Incoming!!..)
Yamariv is offline   Reply With Quote
Old 04-30-2023, 10:36 AM   #12
jacko241
jacko241's Avatar
One of the reasons I was considering replacing it is that there are no radiator shops here anymore.
Old 04-30-2023, 10:47 AM   #13
Ironhorse
Ironhorse's Avatar
They are getting tougher to find but it's well worth your time and effort if you can locate one. We used to have 7-8 shops here in Wichita Kansas area but so many restrictions and EPA rules closed them all but one. It's about a 35 mile drive for me one way but I much prefer to have an original repaired or as an alternative, re-cored. Usually in and out within a week-10 days unless the radiator needs a re-core. Not cheap but then.... cheap usually isn't good and good usually isn't cheap.
Try a Google search for radiator shops or start asking your car/truck buddies and at local car/truck shows. True car and truck people will be your best bet to find the shops you need.
Wellington, Ks
Old 04-30-2023, 11:01 AM   #14
jacko241
jacko241's Avatar
Ha ha I am pretty sure I qualify as true car and truck people, lol. Master certified mechanic for for 45 years, and shop owner for 42 years. I already did the Google thing and none came up near me. Other than for big trucks, heavy equipment, and classics, there is really no need for rad shops.
Old 04-30-2023, 11:29 AM   #15
CKfan
Great looking truck. Good luck with the rad.
CKfan is offline   Reply With Quote
Old 04-30-2023, 03:39 PM   #16
mongo4298
As you all know those original 4 tube radiators were overbuilt for factory installed AC. When my 70 K20 developed a few leaks I located a vintage radiator shop in my community and they flow tested my 4 tube before attempting any repair work. Based on their past experience I was told that they could close up to ten tubes and that I shouldn't experience any overheating problems. I kept my original radiator and the temperature gauge still reads normal. I run a 195 thermostat and have always used a Stant 10 lb cap open system. Mongo4298
mongo4298 is offline   Reply With Quote
Old 04-30-2023, 10:04 PM   #17
'68OrangeSunshine
My truck was originally optioned with AC and came with a 16 lb radiator cap.
AC is long gone, but I still run a 16 lb cap.
While my radiator is in the shop getting rebuilt, I pulled the Battery Box and installed an overflow jug next to it. It's an OER part for an '80s Nova, but it slips right in inside the passenger side fender and is mounted just aft of the Fusible Link Terminal.
I have no prior experience with these, so I'm curious if I should get a lighter rated radiator cap?
Old 04-30-2023, 10:54 PM   #18
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have always run a 16# cap. Pretty sure that's what the factory calls for, and I've never had a problem with it. Also have an aftermarket recovery bottle that was on the truck when I bought it, so I'm using a cap for a sealed system.
- Mike -
RIP El Jay
Old 04-30-2023, 11:03 PM   #19
'68OrangeSunshine
So I need a cap for a sealed system? What am I looking for?
Have a brand and P/N?
Old 05-01-2023, 12:23 AM   #20
Sheepdip
Sheepdip's Avatar
Well I guess I will be the odd man out, I am currently running 3 Champion Aluminum Radiators, one for about 20 years now, another for about 7 years and one in my avatar for about 3 years now, all 3 vehicles have A/C and run thermostatic controlled electric fans.
I have not experienced a single problem with any of them. Just my experience with Champion Radiators.
Sheepdip is offline   Reply With Quote
Old 05-01-2023, 12:44 AM   #21
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I'll check tomorrow and reply here -- maybe I'll get lucky and find some info.
With a recovery tank, you fill the radiator to the top. Shut the engine off at operating temperature and some coolant will be forced out into the tank. (The old way, it would be puked out onto the ground).
As the system cools, your new cap -- which has two seals -- will allow coolant to be drawn back into the radiator. Your old cap, with a single seal, won't do that.
- Mike -
RIP El Jay
Old 05-01-2023, 01:54 AM   #22
'68OrangeSunshine
Thanks.
Not sure how long the shop will be fixing my radiator. I dropped it off Thursday, and they got back to me Friday morning with an estimate. I think they're now the only game in town.
Old 05-01-2023, 09:51 AM   #23
jacko241
jacko241's Avatar
Thanks very much to all for the help and kind words!!
Old 05-01-2023, 01:35 PM   #24
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My radiator cap is stamped MOTORAD 16V and appears to be this one from Summit: https://www.summitracing.com/parts/s...r7PPIUrzRUtyfc
Any parts store should have an equivalent cap. Just be sure it has the double seal.
- Mike -
RIP El Jay
Old 05-01-2023, 03:34 PM   #25
'68OrangeSunshine
Thanks, Stocker, I'll check my local FLAPS.
