05-02-2023, 01:01 AM | #1 |
Squaring up Cab?
Hey Guys Just Wondering What The Best Way To Square Up The Cab To The Frame On My 69 C10 Is?
Any Tips Or Tricks or Places To Measure From. Thanks Posted via Mobile Device |
05-02-2023, 10:18 AM | #2 |
Re: Squaring up Cab?
I cross measured from the outside edges of firewall to the end of the frames. I used one of these ribs on each side of the firewall as the starting point and went to the farthest point on the front edge of the frame
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 05-02-2023 at 10:26 AM. |
05-02-2023, 11:09 AM | #3 |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
05-04-2023, 09:48 PM | #4 |
Measure from the inner rocker to the frame use the same spots for both sides or an X measurement is always a good method like for instance measure the drivers rear inner rocker to the right front fender mount. Do it opposite on the other side the measurements should be the same remember if you have to move go only HALF of the number needed. Jim
05-05-2023, 08:54 AM | #5 |
I start the cab mount bolts and leave them loose then hang the doors, then fenders & rad support. once everything is bolted up and square THEN torque the cab mount bolts
