Old 05-04-2023, 12:39 PM   #1
vardenafil
Removing clutch pedal
I just picked up a 72 k20 truck. The PO converted the truck from manual to automatic transmission. The truck currently has a 700r4 transmission. Where the stick shift would normally be there is a Lokar shift kit. Inside the cab the clutch pedal is still there. I was thinking of removing it as it serves no purpose. However the clutch pedal still seems to be hooked up to something. the clutch pedal is on the floor if i try to pick up the pedal there is extreme resistance. almost like there is a vacuum from hydraulic fluid. Can I remove the clutch assembly? Or is this needed by other systems in the truck?
vardenafil is offline   Reply With Quote
Old 05-04-2023, 01:39 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Removing clutch pedal
I have one removed from the truck.
I can get pictures when I get home.
Just to show you what you are working with.
84 Chevy K-20
Old 05-04-2023, 01:50 PM   #3
72SB
The PO could have secured the pedal with some form of restraint on the firewall side. Stock it would not have been a hydraulic clutch.
72SB is offline   Reply With Quote
Old 05-04-2023, 03:48 PM   #4
tutone
tutone's Avatar
When I went to auto, I removed mine with a die grinder and cutoff wheel. I fought it for about a hour before that.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71
tutone is offline   Reply With Quote
Old 05-04-2023, 07:36 PM   #5
kwmech
It just unbolts and slides out. Unbolt the pinch clamp on the right side. Pull the pedal stop plate off and pull the pedal all the way up to release the spring then slide it out to the left. Not quite that easy but it will come out.
Old 05-04-2023, 10:09 PM   #6
Getter-Done
Here is the pictures I spoke of.
Opinions will follow
84 Chevy K-20
Old 05-04-2023, 10:37 PM   #7
dmjlambert
dmjlambert's Avatar
I wish I had a clutch pedal in my auto transmission truck. I would connect it to sound off an emergency chicken noise maker up in the dash. You don't know what you got until you lose it.
Last edited by dmjlambert; 05-04-2023 at 10:43 PM. Reason: Add more incredibly useful info
dmjlambert is offline   Reply With Quote
Old 05-04-2023, 10:57 PM   #8
Getter-Done
That is Funny right there.
I don't care who you are
84 Chevy K-20
Old 05-04-2023, 11:26 PM   #9
dmjlambert
dmjlambert's Avatar
May seem funny, but I'm cluckin' serious!
Old 05-05-2023, 09:29 AM   #10
Getter-Done
Yeah, I think that's a Great Idea.
84 Chevy K-20
Old 05-05-2023, 12:04 PM   #11
michael bustamante
michael bustamante's Avatar
i thought i was the only one that did this after the struggle!! lol
1967custom
michael bustamante is offline   Reply With Quote
Old 05-05-2023, 01:48 PM   #12
HalfBrit
Here’s a pic of the pedal and what secures it in place. Had mine out while converting to hydraulic. There’s a relatively stiff return spring on the pedal as well
HalfBrit is offline   Reply With Quote
Old 05-06-2023, 01:30 PM   #13
vardenafil
thanks for your help guys. And i do like the idea of hooking up a noise maker to the pedal.
clutch, lokar
