05-11-2023, 09:36 AM | #1 |
Speedo leak
HI ALL I HAVE GMC JIMMY 4x4 1972 There is an Speedo leak . Is there a way to solve this problem ? Thanks
MY Facebook ( saad_alhajri ) on Instagram
05-11-2023, 11:32 AM | #2 |
Re: Speedo leak
Try pulling the Driven Gear Speedometer Sleeve. There should be an O-ring on the bottom between it and the transfer case. I am in the middle of tracking one down right now for mine. Goes where the arrow points.
05-11-2023, 02:54 PM | #3 |
Carpe manana
Re: Speedo leak
Motor City K5 has what you guys need - It's the inner seal. Easy to press out the old one and press in the new.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
05-11-2023, 03:10 PM | #4 |
Re: Speedo leak
Thank you guys, I would like to install it at home. Is there an installation video?
05-11-2023, 04:04 PM | #5 | |
Carpe manana
Re: Speedo leak
05-22-2023, 09:36 AM | #6 | |
Re: Speedo leak
I think that this is the most appropriate solution in my opinion instead of the complete jaw, but what is the O-ring measurement?
05-22-2023, 09:37 AM | #7 | |
Re: Speedo leak
05-22-2023, 11:52 AM | #8 |
Carpe manana
Re: Speedo leak
Mine went in fine and immediately fixed the leak.
Just remembered this: Torqueking.com sells a new speedometer drive adapter nut that has a new sleeve installed. They are a good source for NP205 parts.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 05-22-2023 at 09:20 PM. |
05-23-2023, 01:52 PM | #9 |
Re: Speedo leak
I am still at this stage haha I searched for special socket It’s a thin socket and did not find it to unlock this part.
05-23-2023, 03:15 PM | #10 |
Carpe manana
Re: Speedo leak
Use a 12 point socket it will fit
05-28-2023, 11:36 AM | #11 |
Re: Speedo leak
Thank you sir, the job has been completed successfully
05-28-2023, 01:22 PM | #12 |
Carpe manana
Re: Speedo leak
You bet - happy to hear that's fixed and thanks for the update.
05-28-2023, 02:49 PM | #13 | |
Re: Speedo leak
I am very happy to learn from you. I was able to make a special Socket .
05-28-2023, 03:04 PM | #14 |
Carpe manana
Re: Speedo leak
You WIN! That's awesome.
05-28-2023, 07:16 PM | #15 |
BlahBlahBlah
Re: Speedo leak
Wow, that's very cool you can make your own tools. Nicely done!
05-29-2023, 07:55 AM | #16 |
Re: Speedo leak
Thank you all . I also suspect this speedometer ratio adapter leaking as well . Would I like to exchange it for a new one . Where can I get a new one?
05-29-2023, 11:27 AM | #17 |
Re: Speedo leak
4 screws and it opens. You can clean and replace the grease inside. The gaskets is most likely trash. I resealed mine using a very thing line of silicone.
Some progress is better then no progress |
05-29-2023, 02:58 PM | #18 | |
Carpe manana
Re: Speedo leak
They assembled the one in use on my Blazer and with US parts. I'm extremely pleased with their work. Heck, get a new speedometer cable too
05-29-2023, 03:52 PM | #19 |
Re: Speedo leak
I don't know how to thank you guys. I'm still learning a lot from you
05-29-2023, 04:35 PM | #20 | |
Carpe manana
Re: Speedo leak
05-30-2023, 08:26 AM | #21 | |
Re: Speedo leak
If he leaks again, I will burn the truck hahaha
05-30-2023, 08:31 AM | #22 | |
Re: Speedo leak
06-15-2023, 06:10 AM | #23 |
Re: Speedo leak
We have an old Arabic proverb that says (the last remedy for the ironing problem) I will replace everything new. Thank you all
06-15-2023, 07:43 AM | #24 |
Re: Speedo leak
It has been installed and I hope it will not leak again.
06-15-2023, 07:58 AM | #25 |
Carpe manana
Re: Speedo leak
Nice. Let us know how it works. Inshallah, no leak
