Recommended headers for sbc in my '72
I put a set of Flo-Tech headers on my truck years ago. The gaskets have failed (for about the 10th time) and I need to replace them. It has always been a nightmare to replace the spark plugs on the right side. I would like to know if there are any headers that have enough clearance to be able to remove/install the spark plugs? Any recommendations? Thanks!
1972 Cheyenne (awaiting 2nd Restoration) 1996 Tahoe (Wife's Car) 1968 Volkswagen Beetle (My Daily Driver) 2004 Silverado SS (Can't afford to drive the dang thing with gas at $ 3.00) |
#2 | |
Post Whore
![]() Join Date: Feb 2016
Re: Recommended headers for sbc in my '72
If you don't have access to such a sander then gluing some 60 grit sandpaper (You can start with 36 if the surfaces look really bad) to a flat sturdy bench and holding the header mating surface perfectly flat while moving it back and forth is the next best option. After doing an initial sanding If you find a seriously high spot you can knock it down some with a hand file. Then do another round of sanding. The idea is to get a perfectly flat surface across all four ports. Slowly work your way until all four ports are flat with a minimum of 1/8 of sealing surface. In a perfect world all the sealing surfaces would be the same width across around every port. That way you would get equal crush pressure all the way around the port. There is no way that just tightening the bolts down will achieve equal pressure around every port unless the surfaces are fairly equal in width and true to each other. As far as spark plug clearance it isn't a problem to dimple the header tube so a socket can pass by. Photo #2 shows how my PO dimpled mine using the BFH method as opposed to the heating with a welding torch and massaging the clearance with a socket or short piece of pipe. Unfortunately buying new headers doesn't guarantee the mating surfaces are flat and true across the entire four ports. The same is true for spark plug socket clearance. I actually prefer using used headers as they have taken a set from all the heat cycles over time and usually are more stable. Taking the time to do these steps will give you much longer gasket life. I've had headers on daily drivers for decades getting 30k plus miles on gaskets. Doing a quick check of the bolt tightness every oil change will help keep those headers sealed. https://www.mcmaster.com/products/ad.../grit~60-grit/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Jan 2001
I have an alternative recommendation. When I put in my new L31, I ditched my headers and went with 2 1/2" rams horn manifolds. They flow just as well, and I don't have all the headaches that come with headers.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
OP, while you do want header flange flat, sometimes they are not dead nuts. Remflex gaskets are quite thick and work well for headers that are not perfect flat. Obviously, there are limits but try a set. They also note retightening is not needed.
For plugs make a slotted socket out of a donor plug socket. Also using open end wrench can access tight to tube headers. cut some off the wrench end and remove 1/5 of the side so the socket comes in sideways, then down towards head. Use box wrench on the socket to loosen plug. Remove socket and take out plug by hand |
I put these on my ‘70 C10 with a 350.
Fit perfect with a great finish. Zero problems changing plugs. I used the gaskets with thin layer of copper gasket maker. Been on 5 years now with no issues. https://www.summitracing.com/parts/s...ckup/year/1972
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
#6 | |
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. ![]() |
Agree.... cast iron on my Big Block... under hood heat is also reduced.
Have you tried the thicker gaskets that will compress to take up uneven surface conditions. I had sealing issues with a cheap set of summit headers to a cheap set of Edelbrock heads because there was a pretty close edge of the header opening to the port. This gasket fixed my problem. Remflex 2007 D-Shaped Port Exhaust Header Gasket This is a D port cut but they make other configs to match your head. Also, be sure to match header and head port shape or you will struggle to keep things sealed. Quick free shipping on Amazon for this product.
![]() Join Date: May 2004
I have no experience doing this, but a friend told me he used to cut the flanges between cylinders 1 & 3 and then 5 & 7 on the drivers side....2 &4 and then 6 & 8 on the passengers side. This allows the flanges to be tightened down individually for each cylinder except for 3/5 and 4/6.
Well, I replaced the header gaskets, valve cover gaskets, and spark plugs over the last couple of days. NOT a job for an old man like me! The next time, I will probably change back to "Ram's Horn" exhaust manifolds. The removal of the A/C compressor and the fact that the header bolts were difficult to line back up was ridiculous. I just need to finish up the driver side (the "easy" side) today. Hopefully she'll run a little better, now. Without oil leaks.
#11 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
+1 on the Remflex gasket. Fixed my issue with some cheapo summit headers.
#13 |
![]() Join Date: Dec 2012
Same for me!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
