05-16-2023, 09:52 AM | #1 |
Door adjustment
Today's goal, passenger door alignment. Driver side is just about perfect but passenger is annoying me to no end.
Hinges are rebuilt. I have to slam door to latch tightly. Facing closed door. Hinges are to my right. Latch to my left. Top right is too far in. Bottom left is too far out. Bottom right is a little out. Latch is lined up, no need to lift door to close, just slam. I have loosened and played with everything. No luck. I have not cut any metal or used the grinder at all at this point. I have also not tried to bend the hinges.
1950 Build |
05-16-2023, 09:53 AM | #2 |
Re: Door adjustment
More pictures.
1950 Build |
05-16-2023, 02:15 PM | #3 |
Re: Door adjustment
New or old door rubbers?
Are the door, cab and rebuilt hinges all original, matches pieces that had good door gaps before you started? I made the mistake of having 2 cabs worth of hinges all stored in one box, then rebuilding the 'best' ones rather than original matching ones. And installing the door rubber before the alignment was spot on. I lost count of how many times the doors and hinges came off for bending and slot lengthening. Somewhere along that journey my vision of desired level of panel gap became 'not hitting the frame anywhere'. |
05-16-2023, 02:53 PM | #4 |
Re: Door adjustment
I dont think I mixed them up. Driver side is good. All original. Honestly I don't remember what it looked like before. I'll look through my pictures.
1950 Build |
05-16-2023, 02:55 PM | #5 |
Re: Door adjustment
When I first bought it. Best picture I could find.
1950 Build |
05-16-2023, 03:17 PM | #6 |
Re: Door adjustment
the before picture looks like a good fit far as I can see.
I'd try removing the striker plate and concentrate on alignment then add back the striker plate to pull the back of the door in as last step. It looks like you need to go in on bottom hinge and forward on top. there are some detailed tutorials on the forum / Internet that may be better than my advise. I did lower my standards to fit the doors rather than fit the doors to my standards. |
05-16-2023, 03:36 PM | #8 |
Re: Door adjustment
Front edge.
1950 Build |
05-16-2023, 04:39 PM | #9 |
Re: Door adjustment
Ok so the bottom of the door needs to move in here’s a video I made to try and help with this problem. It takes very little to move the door a lot.
https://www.youtube.com/watch?v=-Tq5aiB8s44&t=135s
Jan's 53 |
05-16-2023, 05:44 PM | #10 | |
Re: Door adjustment
1950 Build |
05-16-2023, 05:50 PM | #11 |
Re: Door adjustment
Do both hinges need that treatment or just the bottom?
1950 Build |
05-16-2023, 06:08 PM | #12 |
Re: Door adjustment
Depends on if it is sitting flush with the cowl. What this does is move the door in and out. The horizontal and vertical is adjusted with the bolts on the inside of the door where the hinge mounts.
Jan's 53 |
05-17-2023, 02:58 PM | #13 |
Re: Door adjustment
Is the cab sitting square and level on the frame with good mounts? If the mounts are sagging a bit the cab may be twisted a tiny bit.
Before I went crazy I would make sure that the frame is sitting square and even distances from the shop floor (side to side) and measure the clearance between the frame rail and the floorboards. If all is good there then I would go on to the next step (s).
05-17-2023, 06:40 PM | #14 | |
Re: Door adjustment
Did I understand you right? Bend the hinge out to move the door in? And bend the hinge in to move the door out?
1950 Build |
