Old 05-17-2023, 05:37 PM   #1
425HP409
425hp409
425HP409's Avatar
Driveshaft question
I am converting my 68 short bed from small block, TH700R4 and 2 piece driveshaft to a 396, TH700 R4. Since I have to move the transmission back 1.5" to accommodate the engine, can I use a one piece driveshaft that will be 58" long?
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 05-17-2023, 10:16 PM   #2
LS short box
Re: Driveshaft question
I always rely on my some what local drive shaft shop for their direction. Length, diameter and max engine rpm all factor into the design of the drive shaft. I would upgrade to 1350 u-joints.
LS short box is offline   Reply With Quote
Old 05-17-2023, 11:03 PM   #3
cornerstone
cornerstone's Avatar
I went from a long bed to a short bed and I'm running a driveshaft a little longer than 58", based on several other builds I studied. I'm not on the road yet so take that for what it's worth.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 05-17-2023, 11:53 PM   #4
68bowtie
68bowtie's Avatar
I have a swb 396/700r4 with a single piece ds. I want to say it was 58.5” but that’s just from memory.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 05-18-2023, 10:36 AM   #5
HO455
Post Whore
HO455's Avatar
Part of what determines the limits of drive line length is the intended usage along with gear ratio, tire diameter, transmission top gear ratio, engine horsepower. These factors determine the maximum RPM of the driveline as well as how much torque it will be required to absorb.
There is a maximum RPM that a drive line can turn at before it starts it reaches critical speed. The length, diameter, and material used in the driveline determine its critical speed. The critical speed is basically the RPM at which the drive line starts to whip or bend so it resembles a jump rope which can be felt as a vibration in the vehicle. Exceeding the critical speed will lead to driveline failure due to fatiguing of the driveline material. The longer time and/or the greater amount of RPM you exceed the critical speed causes the failure to happen sooner.
Spicer has calculator to help determine what the critical speed of your driveline would be.
https://spicerparts.com/calculators/...rpm-calculator
Then you need to calculate what the maximum RPM your driveline would turn at to see if you're in danger of exceeding the critical speed.
https://www.dennysdriveshaft.com/pot...alculator.html
RIP Bob Parks.
