Plastic glove box insert
Anyone buying and installing plastic glove box inserts? Best brand? Easy to install? 72 C10 w/air.
Thanks |
![]() Join Date: Dec 1999
Re: Plastic glove box insert
Never have seen plastic reproductions. I have seen some really shallow plastic glove box inserts for use with aftermarket A/C units.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Is there one made now? I recall when a prototype was in the works quite a few years ago. I don't know what came of that but never heard talk about plastic glovebox inserts till now
Yes they are made. Old Air products, LMC, and CJ Pony to name a few. I need to remove my cardboard one to work on the radio. I'll most likely ruin it when removing. Thought it would be a good time to try one. They're made for trucks with and without a/c just like the originals. Reason I ask if anyone has tried them is installation ease. I know the originals need to be massaged into place by slightly bending. Don't know how bendable the plastic might be to "massage" it into place. They're probably all made by the same company. Regardless I will be buying one from somebody.
Yeah, I'd hope they took into account making them flexible as the cardboard ones. Hopefully someone who has one will see this
Subbed for outcome.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Me too, subbed!! Just took mine out for some under dash service and she crumbled apart..
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
They are a lot easier to install if you let it sit in the sun for a few hours.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Do they install through the hole or have to mount them from behind? With the mods I have done I couldn't put it in from behind. There wouldn't be enough room.
But that would not be original
![]() Join Date: Mar 2011
me 3
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
In this case, a plastic one should have been in there from the start so I'd consider that original
#13 |
I have an Old Air Products plastic one in my truck. It fit close to perfect.
#14 |
Why ? Mine has the original fiber liner not bad for a 51 year old vehicle . I have to replace the plastic one in my 85 it's all cracked and falling out .
#15 |
They install through the front hole. When I did mine, I put the drivers side in and slid it towards the drivers side and then got the other side in and slid it back. I have the vintage air, from their air kit.
#16 |
![]() Join Date: Dec 2014
I have the LMC plastic insert for A/C. Needed the extra space for defrost ducting. Seems okay, installed from the front and then rotate to set behind the glove box lip. Small notch for the glove box bulb is kind of a problem, kept hitting the bulb and having it fall apart. I have the cheaper replacement bulb, also from LMC. Just need to remove the bulb and then install it after the liner.
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears |
