Old 05-22-2023, 11:44 AM   #1
Bunky
Question Sway bar 67 C10
I'm planning on adding a sway bar to 67 C15, I have read several post on here about using the 73-87 sway bars. Thinking I'm going to go this route I was wondering if a 3/4 ton saw var too much for only having a 6 cylinder?
Bunky is offline   Reply With Quote
Old 05-22-2023, 10:28 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Sway bar 67 C10
Nah, definitely not too much. Sway bars don't care what engine you have in it, they just care about how you drive it. If you like more stability around corners, you'll like the 3/4 ton bar
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 05-23-2023, 03:46 PM   #3
SCOTI
SCOTI's Avatar
Re: Sway bar 67 C10
x2.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-23-2023, 04:22 AM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Sway bar 67 C10
I had the factory 7/8 inch sway bar on my truck but swapped it for a 1 1/4 bar from a 73-87 1 ton.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-01-2023, 12:12 AM   #5
Warrens69GMC
Warrens69GMC's Avatar
Re: Sway bar 67 C10
I have a 1976 C20 frame I'm pulling the front sway bar (26mm) and putting it on my 1967
1967 gmc, sway bar
