Old 06-01-2023, 10:05 PM   #1
snowball
Intermittent brake lights
HI all,
I'm having intermittent problems with my brake lights.
Tracked it down to the fuse box. it's lose and shaking it gets the lights on and off.
Anybody run into this before?
1990 suburban r1500 k 350 2wd
snowball is offline   Reply With Quote
Old 06-22-2023, 05:22 PM   #2
RaTcheTmasTer
Automania
RaTcheTmasTer's Avatar
Re: Intermittent brake lights
The fuse box is shaking?
there are two screws inside in opposite corners of the box under the dash., and one screw in the middle on the outside I believe. check the harnesses on the outside that they are plugged in completely.
check the screws that join the inside fuse assembly with the outside firewall where the front and rear harnesses attach. by the brake booster.
I think the real light harness goes under the truck. follow if from the rear of the truck forward and make sure everything is tight.
RaTcheTmasTer is offline   Reply With Quote
