Old 06-04-2023, 05:50 PM   #1
snowball
Depin reverse light socket
Hi all,
My reverse light socket is falling apart frrom the outside. The connectors are still good. I hate hacking wiring. is there a way to depin the old connector and replace it with the new housing?
TIA!
1990 suburban r1500 k 350 2wd
snowball is offline   Reply With Quote
Old 06-04-2023, 09:17 PM   #2
snowball
Re: Depin reverse light socket
Figured it out.
The ground can be depinned by putting a screwdriver from the insulated side and depressing the tab. the positive center requires a shim from the bulb side. there are 2 tabs but only 1 is attached. wiggling it will show where it is locked.
