06-06-2023, 07:44 PM | #1 |
Gas/Oil Contamination ?
I had to replace the fuel pump on my 307 and discovered that the diaphragm was leaking fuel into the oil pan. I had just replaced the oil and filter less than 100 miles prior. Is the filter still ok or do you recommend replacing it also ? Oil level was a bit higher than max on dip stick.
71 C-20 07 Magnum RT AWD |
