small starter
i put one of the small starters on my 71 c/10 a couple years ago and need to put a new stater on a 65 327 motor now. bolts are straight across not off-set. can one of you refresh my memory as to which one i need to order? thanks!
Re: small starter
I use this one on my 67 327 and now have it on my BPE 355. Its a gear reduction starter
https://www.rockauto.com/en/moreinfo...=3882534&jsn=1 |
Re: small starter
thanks, i'll check it out.
Re: small starter
i can't find that part listed by part number or by description. could you tell me what model, year, and a price for it? maybe discontinued item? thanks
Re: small starter
I, and several others on a 1st gen Camaro forum, got that starter on Rockauto for around $70. It is a permanent magnet gear reduction starter. I bought mine a few years ago, maybe they don't carry them anymore. Its a new starter, not reman.
Here is the Remp part # listing and cross refrence chart from the 10MT to PG starter with or without the R terminal for 153 or 168 tooth FW https://autoprollc.com/wp-content/up...eb2016_web.pdf |
Re: small starter
thanks
Knuckle Buster, Instructor
![]() Join Date: May 2010
Re: small starter
The bolt pattern on a stock GM starter changes based on the flywheel/flexplate diameter. 153 teeth or 12.75" uses the straight pattern and 168 teeth or 14" uses the diagonal pattern. If you have a straight pattern, it's most likely a car engine. I've never seen a truck with the small flexplate. When looking for a replacement, most aftermarket gear reductions will reference the tooth count/size or some will have dual patterns that will work with either.
Current classic fleet: 72 K5 Blazer CST, unrestored factory Orange paint...mostly 69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration 53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue |
