06-28-2023, 02:31 PM | #1 |
Fleetside bed mat
Hi. I'm looking a bed mat that would fit a 66 C10 fleetside. I have a short bed, but I can cut down anything that would fit.
Has anyone tried a 67-72 mat in a 60-66 fleetside? It's tough to find dimensions of truck beds, not just L x W but where the wheel arches are, or id just compare measurements. I read posts about mold growing under mats, but this is for temporary use for hauling stuff. Also, if you don't use a bed mat, what do y'all do to protect the bed wood when you're hauling stuff? Sheet of plywood, cardboard...? Thanks for reading, and for any ideas. |
06-28-2023, 02:51 PM | #2 |
Re: Fleetside bed mat
Can't believe I forgot the obligatory photo.
06-28-2023, 02:56 PM | #3 |
Maybe consider a "horse stall matt"? Cut to form
John 3:16 - Saved me... God Bless |
06-28-2023, 03:57 PM | #4 |
Revitalizing a 6T C10
nice looking truck...
as far as temp use - like 88 Stanger said - Tractor Supply had some thick (3/4 in) rubber 6ft x4.5 foot mats for like $20 not too long ago you might even be able to get some carpet remnants - you could even put the carpet side down to not damage the wood. or a few refrigerator boxes?
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
06-28-2023, 07:32 PM | #5 |
Since I couldn't find a custom sized mat I just went with the one from Summit Racing. It fits from the cab to the tailgate and between the wheel wells.
https://www.summitracing.com/parts/sum-5005 |
06-28-2023, 07:46 PM | #6 | |
The edges aren't exactly cut clean so you'd have to use a straight edge if you wanted a clean seam... not hard to do with a utility knife and a new blade, it just takes multiple passes. |
06-28-2023, 11:17 PM | #7 |
I put 60-66 long bed sides on a 67-72 long bed steel floor. Used the 60-66 wheel tubs. Every bolt lined up perfectly. If you can source a 67-72 mat, I think it'll work for 60-66.
Please let us know what you end up doing. I've been throwing a moving blanket in when hauling other 60-66 parts, but would like to find something more durable for when I want to haul some heavier things. It would be nice to have a mat that's light enough to remove easily when not hauling so the bed wood, arguably the nicest part of my entire truck, can be visible
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-29-2023, 03:53 AM | #8 |
Great ideas. Much appreciated. Especially good to know the 67-72 sides bolted up. With that in mind, I may try the Holley 67-72 mat and see how it fits...if the Tractor Supply mats aren't still on sale.
Either way, I'll report back. Thanks |
06-30-2023, 02:55 AM | #9 |
Yea i dont think anyone sells a bed mat for 60-66 trucks.. best bet would be to make a 67-72 mat work.. or another option is look on Facebook marketplace for 4 x 8 gym mats.. people usually sell em for $30-40 dollars and they are thick..just an idea..
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
Tags |
bed mat, bed wood, fleetside |
