06-30-2023, 01:47 PM | #1 |
WTB 69-72 4x4 SWB Frame
Looking for a decent SWB 4x4 frame....
bare frame preferred but will consider a roller. Preferably in the TN, KY, NC, SC, GA, AL, MS, FL region...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. Last edited by A1971Blazer; 07-01-2023 at 06:26 PM. |
07-01-2023, 12:03 AM | #2 |
Re: WTB 69-72 4x4 SWB Frame
I’m curious why not 67-68 as well or are you wanting a blazer/jimmy frame not truck.
Some progress is better then no progress |
07-01-2023, 06:55 AM | #3 | |
Basically just looking for the easiest and quickest way to build a SWB 4x4 without a great deal of fab work. I can do it, but just don’t really want to. If I can’t find a good frame, I will just have to modify my 2wd frame. This project is a ways out yet but i’m looking for stuff i will need
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
07-01-2023, 12:28 PM | #4 | |
It will be next year before i start the project…If I don’t find one, i’ll just use the parts off the Blazer frame and 4 link the rear..a trailing arm set up with coilovers might work as well
07-01-2023, 02:30 PM | #5 |
Hammer On!
You won't want a 68 frame either if you're not interested in modifying the frame. Currently I'm working on a 68 K10 and have to modify the frame for power steering by means of CaptainFABs bracket. Just thought you might like to know!
1968 C20 Inline 6 250 SM465 4 speed 1968 K10 Inline 6 250 SM465 4 speed |
07-01-2023, 04:46 PM | #6 | |
I had thought the PS gear mounting surface changed for the '68 MY....did it have the hydraulic ram assembly like the '67 did ?
07-01-2023, 05:07 PM | #7 |
Always on the hunt...
No, not on the K frames, no frame mounted power steering gear until 69 on the 4wd's. Imho, your WTB "69-72 4x4 frame" thread is correctly titled and what we would also be chasing for the p/s and upgraded forward spring hanger (also a 69 K frame design change) reasons. Good luck on the hunt! Mel
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our paypal account & info has been changed as of Jan. 2022. Thanks... |
07-01-2023, 06:22 PM | #8 |
More good info….thanks for the input…
07-01-2023, 09:34 PM | #9 |
67 4x4 frame also has one year only 3" rear springs.
07-02-2023, 06:47 AM | #10 |
I've had a few 72 swb 4x4s and each of them had a reinforcement bracket on the inside of the frame for the steering box. They also had a bracket on the driver's side front spring hanger, and an L-bracket on the frame behind the spring to retain the spring in place if the spring should brake. Another difference is the 72s have different / taller rear forward spring brackets. Some of these changes may have started in 71.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
07-03-2023, 07:36 AM | #11 |
A lot of good information...
Looking at the production numbers reveals that there just weren't a great deal of 4WD SWB models produced. Model years '71 & '72 saw the highest production numbers and, by observation, they populate the list for availability. The search continues.......
07-03-2023, 11:07 AM | #12 |
Would you be interested in a cut down lwb frame? Not mine, but I know where one could be bought.
07-03-2023, 04:31 PM | #13 |
Hammer On!
The 3" rear springs were used on the '68 K trucks as well. The other oddity about those rear springs is that they start at 3" on both ends but slim down to 2.5" in the middle. NOT any easy solution to replace!
04-14-2024, 04:21 PM | #14 |
Why can’t you just use a 2wd short bed frame
04-14-2024, 04:41 PM | #15 |
Not a big deal to overcome. I believe when replacement springs are ordered for these the 2.5" leaf is used with wider bushings at the ends.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-14-2024, 09:29 PM | #16 |
Born Psycho
71-72 4x4 frames also have an extra reinforcement bracket on the rear spring hangers that are riveted to the underside of the frame rails. 69-70 spring hangers only riveted to the side of the rails. i used 72 blazer rear hangers on my 69 suburban for the extra support. i also installed the steering box inner support bracket from the blazer.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
04-15-2024, 07:43 AM | #17 | |
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
