07-08-2023, 02:25 PM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
How much of a rebuild is needed on this 350?
I picked up this engine from a person who said it was rebuilt. It was fully assembled and running. So yeah, the pistons read 030. The pistons were dirty so I cleaned them off. I still see cross hatches but one bore shows rust. Maybe it sat too long?? Should I completely disassembled the block and have a shop deep clean and inspect it??
07-08-2023, 02:29 PM | #2 |
Re: How much of a rebuild is needed on this 350?
One more
07-08-2023, 03:12 PM | #3 |
Who Changed This?
Can you measure the height of the ring ridge? That alone could dictate another bore job; once you're that far in might as well do it all. If you just want to ring & hone, you'll need to remove that ridge. Plus, you're going to get some blow-by on the rusted cylinder.
07-17-2023, 11:00 AM | #4 |
I personally see no reason not to run it as is.
Cheers |
07-17-2023, 11:15 AM | #5 |
First of all, a rebuild means go all the way, new pistons and all. Anything less is an overhaul. I'd either run yours as is and use it up or bore and re-ring. If bigger pistons are needed it's go all the way for me
07-17-2023, 05:08 PM | #6 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Appearance wise it dont look bad except for that one rusty hole. If you dont have a bore gauge to measure the holes then I would at least run a ball hone down that rusty hole to clean it up. Lay a paper towel on top of the piston at BDC squirt some WD-40 in the hole and give it a few quick strokes with a ball hone. Slap it together and run it if all the valve seats look good.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
07-20-2023, 07:11 PM | #7 |
Could you give that rusty cylinder a clean up with some wet 1000 grit paper ? Looks like it’s just sitting on the surface.
71 C-20 07 Magnum RT AWD |
07-20-2023, 10:01 PM | #8 |
07-21-2023, 01:16 PM | #9 |
Post Whore
What are your plans for the engine? That is the big decider with what I see in the photos.
Pulling the base plate on the oil pump and inspecting the pumps internals will give you a idea as to the condition of the bearings. That may help you determine the course to steer.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-25-2023, 01:30 PM | #10 |
Run it.
07-25-2023, 03:28 PM | #11 |
That does not look like a fresh build-too much stuff at the top. That said I would probably try to clean the rust with a scotchbrite pad and run it. You may lose some compression in that one and the other one with a mark in it, but I'd roll the dice and try it.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
07-26-2023, 12:37 AM | #12 |
Yeah, I threw in the towel. Decided to take the block to a shop for cleaning, decking, machining, etc.
