Old 07-13-2023, 02:19 PM   #1
nvrdone
cab insulation
Ok, I'm at the point of needing to insulate the cab against heat. Any recommendations from anyone about what works good?
Thanks.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 07-13-2023, 02:26 PM   #2
Hcb3200
Re: cab insulation
More details please.
Are you doing a true restoration.
Just building a resto-mod and you don't want to roast.
Showing it, driving it daily or just letting it sit in garage.
Covering it with what material.
Want authentic or modern material
etc etc.
Hcb3200 is offline   Reply With Quote
Old 07-13-2023, 05:01 PM   #3
nvrdone
Re: cab insulation
It's a fair weather driver. Just dont want to roast. Floor is covered with carpet. Right now our daily temp is mid 90's and it gets rather hot in the cab.
Old 07-13-2023, 05:11 PM   #4
Getter-Done
Getter-Done's Avatar
Re: cab insulation
My Nephew and I put Kilmat and closed cell foam in his 83 chevy and it made a Huge differance in heat and road noise issues.
A roller makes easy work on this stuff.
Link: https://www.amazon.com/Kilmat-Deaden...7&sr=8-18&th=1
Link: https://www.amazon.com/Sound-Deadeni...0751CBXBT?th=1
Link: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
84 Chevy K-20
Old 07-13-2023, 05:50 PM   #5
Hcb3200
Re: cab insulation
I agree the roll on sticky stuff seems to really be in a lot of trucks lately.
many brands and the local restoration shops can help you out with some deals
The old school jute matting or fibers can work but I don't like it because if water comes in it soaks it like a sponge and takes forever to dry.
Also what did work really well on some heat issue was well placed metal heat shield under cab where exhaust was running. This way the cab flow was not getting that radiating heating. Especially here in the south with these 90% days.
Old 07-13-2023, 07:04 PM   #6
mr48chev
mr48chev's Avatar
Re: cab insulation
Agreed with the heat shields with a bit of air space between them and the floorboards. I'll let the muffler shop figure out where they want to put the mufflers and then install heat shields above them if they are under the cab.
This is a homework exercise for me because I want to know what people have used and if they think it works
My ongoing truck projects:
Old 07-14-2023, 01:49 AM   #7
leegreen
Re: cab insulation
I used Killmat from Amazon and am happy with the product, but after I bought it I learned it is made in a country that is in the process of a protracted invasion of a neighboring country. I'd not have bought it knowing that in advance. But decide for yourself.
Anyway, I did the rear of cab, floors, ceiling and as much inside the doors and up the firewall as I could. The floor also has a rubber floor mat on it. It made the cab feel very solid and quite.
My exhaust exists under running board just behind cab. It has quite a drone noise, so until I make a longer tailpipe I can't report further on how well killmat blocks road noise.
leegreen is offline   Reply With Quote
Old 07-14-2023, 01:45 PM   #8
e015475
e015475's Avatar
Re: cab insulation
Killmat and similar foil-faced sound deadening material are good for vibration damping of sheet metal but will only help a little with controlling heat.
The rule-of-thumb for Killmat and the like is that 65% coverage will damp a panel to about 95% of what covering it 100% would, so that's what I shoot for. I used the 80 mil Killmat in the cab of the truck. Took about a box and a half.
To control heat coming into the cab, I put about .25" of self stick closed cell foam. Unlike the Killmat, you need as much coverage as you can. I did the roof, firewall and floorboards, including under the seat with foam. The vertical panels behind the seat will also get covered with foam 100% (but Killmat to 65%)
I met a guy at a car club event that was an NVH engineer for Nissan. He said that the car manufacturers were beginning to use carpet with a mass loaded vinyl backing in an effort to quiet interiors even more. You can buy mass loaded vinyl at HD and do it yourself, but I think that's over the top for an old truck and I'm going to go with a jute backing under the carpets.
e015475 is offline   Reply With Quote
Old 07-14-2023, 01:48 PM   #9
e015475
e015475's Avatar
Re: cab insulation
Oh. I think the idea of a heatshield to cut down the radiant heat from the exhaust is a great idea - going to do that too.
Old 07-14-2023, 05:37 PM   #10
dsraven
Re: cab insulation
the best thing to control heat from exhaust is a light metal heat shield spaced off the underside of the floor a little. look under any new car where the exhaust routes, it's there. they don't do stuff like that because they wanna run another line at the factory, lol.
has anybody with sound deadener mat on the truck floor had an issue wuith it becase it got too from the exhaust?
my son did an S10 when he was just out of school. he used the deadener and the felt style underlay under the carpet. warm in winter, cool in summer and pretty quiet inside (for an 82 S10)
Old 07-15-2023, 07:14 AM   #11
scott123
Re: cab insulation
Most any of the brands will work. I ordered the Summit brand in my last truck. The pic looked like a roll but when it came it was rolled but was actually like 16"X16" sticky back squares. It is a 69 Chevrolet and I think it helps pretty good with the sound and maybe some with the heat. (Like anything between the heat source and you carries some 'R' rating but how much? Who knows?)
As stated before a light piece of sheet metal that provides a heat shield as well as a heat sync with an air gap on either side is maybe the most effective way to avoid heat making its way into the cab.
I have a buddy who used the foil back rolls of insulation from Lowe's and his 72 feels as good as my 69.
Scott
scott123 is offline   Reply With Quote
Old 07-15-2023, 04:50 PM   #12
unclebrad
unclebrad's Avatar
Re: cab insulation
Not exactly cab insulation but I bought some exhaust pipe wrap, mostly to protect the fuel line and starter from heat, but I have to think that, if it is keeping the exhaust heat moving through the pipes, it is probably helping with cab heat too. Every little thing helps, right?
55 Cameo w/ 409/700r4
unclebrad is offline   Reply With Quote
Old 07-15-2023, 05:25 PM   #13
Getter-Done
Re: cab insulation
For Sure
I used this stuff on a similar project.
It really helps
84 Chevy K-20
Old 07-17-2023, 01:28 PM   #14
Florida5100
Re: cab insulation
Kilmat all over plus OEM firewall backing, coated headers and Vintage Air A/C keeps me comfortable in South Florida heat.
Only bad part is my original-style vinyl seat which induces sweat even when its cool out.
1950 3100 purchased in 1987 (first car). Parked in 1991
Completed 6/23:
Blueprint 350 SBC / T5, 10-bolt
Heidts SuperRide II / 4-link / coil-overs / Wilwood disc
47-style gas tank / 54-style side spare / vintage Fulton
On the road again ...
Florida5100 is offline   Reply With Quote
Old 07-18-2023, 12:52 PM   #15
jweb
jweb's Avatar
Re: cab insulation
Most heat will come from the firewall. So first start by making sure you have all holes sealed. Add Killmat ( or similar) and closed cell foam.
If you have a stock style heater make sure you have a shut off valve. You can get a lot of heat from the water circulating through the heater core.
For the floor, back of the cab and roof. Do the same as the firewall.
If you're concern is noise add Killmat in the doors and make sure you have good seals everywhere.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 07-18-2023, 05:38 PM   #16
schovil69
Re: cab insulation
I used a layer of Siless sounds deadening plus a layer of Siless heat shield in a '56 Belair recently. I expect it to do what it's designed to do but haven't been able to find out yet.
schovil69 is offline   Reply With Quote
Old 07-18-2023, 07:48 PM   #17
vintovka
vintovka's Avatar
Re: cab insulation
Anyone concerned about moisture accumulation and rust under these coverings?
vintovka is offline   Reply With Quote
Old 07-18-2023, 09:59 PM   #18
nvrdone
Re: cab insulation
all the info i'm finding says that because the product is closed cell, they do not allow moisture between the insulation and the floor.
Old 07-18-2023, 11:11 PM   #19
fauXGT
fauXGT's Avatar
Re: cab insulation
I wanted to stay with the stock look by applying 'Lizzard Skin' to inside, including floor, fire wall, under dash, roof, inside doors and in corners. Sprays out like paper mache thru a straw but gets into cracks and crevices. Sprayed extra on floor/firewall/kick panels to sand flat and then primer/paint. Still in primer. Alot of work, but amazed at the sound suppression so far. Next is heat check.
Chip
'51 Chevy 3600 5 window
C4 Vette front/rear suspension & drive train
full Rusto-Mod
'92 GMC Sonoma GT VIN #0015
'91 GMC Sonoma GT extended cab 1 of 1
fauXGT is offline   Reply With Quote
