Who Changed This?
![]() Join Date: Jan 2013
Grill Replacement
I have a butchered '71-'72 grill on my truck. I'm looking at replacing it with a new correct grill, but looking at the parts needed, I'll have to buy brackets specific to '69-'70. I'm curious how different the '71-'72 grill brackets are and if I can retrofit. Anyone who has more experience than I have any pointers?
#2 | |
![]() Join Date: Aug 2014
Re: Grill Replacement
The outer grill brackets are the same on both no mods needed. If your wanting to change from 71-72 grill to 69-70 all you will need is the center support as they are different and you would need to change the front bumper as the 69-70 park lights are in grill not the bumper like 71-72.
Az |
Who Changed This?
Thanks! Part of the butchery is that the park lamps are mounted into cutouts in the grille- the front bumper is the original '70 bumper.
#4 | |
That will make things easier and take less time that’s a win win
Az |
![]() Join Date: Dec 1999
I think you only need the grill surround and grill insert hardware kit. As said side brackets are the same and I would bet the center support/latch is your original. I have the grill insert for you. Will give you a hand installing if you like.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Who Changed This?
Next question. My headlight bezels are black, appear to be painted. Looking at the "Front End Friday" thread, I'm seeing both chrome (or at least shiny) and black. Some also appear to be body color, but I don't want orange "punkin" eyes on my truck.
![]() Join Date: Jan 2012
69-70 bezels were painted black and made of steel from the factory. To my knowledge, these steel bezel are not reproduced. 71-72 were lighter weight (aluminum?) and unpainted. These are available as reproductions. Any other color is a custom touch.
![]() ![]() Join Date: Jul 2002
You may also need to change the center hood release if you are going back to 70 style grille. Not sure what they used on yours since they added the 71/72 grille. The lights don't look bad in there.
#9 | |
Who Changed This?
Thanks, I'll have to look at the artwork at the vendor more closely to determine if the center bracket and so forth are correct for the '70 grille.
I have not ever owned a 71/72, but I know they have different part#s. also as pointed out in the videos, the center grill support is different for 69/70 and 71/72
https://www.youtube.com/watch?v=3FoOVAx1stg https://www.youtube.com/watch?v=_qGl7sj5p_4
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 07-21-2023 at 09:59 AM. |
Who Changed This?
True, that center bracket is quite different. I have that in my shopping cart, as well. Thanks for the videos. Looks like the hood latch is different, too. Except I went and looked. My FiL used the original '70 hood latch- the lever isn't offset like in '71-'72.
One of the First
![]() Join Date: Jan 2000
California - I would bet you can find all OE parts around there. I would say a lot better quality and less expensive. I like the 69/70 grills, but never was a fan of the bowtie mounted up on the hood face.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#13 |
![]() Join Date: May 2012
I just replaced my inner and outer. I bought a chrome from LMC and it is super nice But I don’t have the Aluminum trim anymore and I have a lot of chrome on my truck. Tool wise, locate your pop riveter, you’ll need it to install the inner. Getting a new outter is a worthwhile expense. You will love it
![]() J
White K20 |
#14 |
Who Changed This?
Pretty sure I have two pop rivet tools. Loaning tools, then forgetting, buying another, then the borrower returning it, years later. Happened more than once (but not with the riveter).
![]() Looking at the installation kit, I'm betting I have enough fasteners around here (and hundreds of pop rivets) to install everything.
#15 | |
![]() Have fun! j
White K20 |
#16 |
Here's my new grill from LMC.
White K20 |
#17 |
Who Changed This?
^ Sure is purty! I see you have chrome headlight bezels. I'm going to leave mine back, but with a repaint.
#18 | |
The new grill came with the chrome bezels. I was going to stay with black but the originals are badly pitted, so is my original aluminum grill. Like an old sand blasted windshield. So, I just used the chrome. I would have had to buy new black ones. My color scheme is chrome and white anyway. I'd stay with black if I were you. But you might get new bezels shipped with your grill. If so, they probably won't be black. ![]() j
White K20 |
#19 | |
Who Changed This?
#20 |
It's my understanding that those "new" non-steel bezels dent/ding fairly easily and don't hold paint well if you decide to go with the original black color bezels. I've seen several of the new cheapo/thin repops with peeling black paint on them. Definitely will want to refinish your original steel ones if you want that look. Also, instead of pop rivets they make smooth headed bolts with lock washers and nuts that look much like the original smooth rivets used to attach the outer grill to the brackets. Pop rivets are a dead giveaway that the grill has been replaced on one of these trucks. In your first pic in this thread it appears that someone must've modified your original 1970 grill because there appears to be a smooth headed black rivet above the headlight bezel which means the grill hasn't been replaced.
I think these are the correct size (might want to search the forum for accuracy) rivet screws that folks are using instead of pop rivets for a much nicer look IMHO. The heads could be paint black to match the factory look. https://www.ebay.com/itm/132404770155 |
#21 | |
Who Changed This?
#22 |
![]() Join Date: Mar 2011
subd...good info I got a box of the center braces and hood releases going to I D and put them up for sale
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#23 |
Who Changed This?
Yeah, that Chad guy was pretty good at explaining it all. Saved me from buying a hood latch I didn't need. Him and Palf70step (thank you very much!). Gonna sand my headlight bezels down and paint 'em nice and black, too.
