07-18-2023, 10:28 PM | #1 |
54 running dimensions
I'm have a hard time getting my truck done. I took the truck to the body shop about 4 weeks ago, They were painting the rear fender and fixing a couple rock chip. While it was there I asked them to install the fenders. He called and told me I had the wrong running boards? what the heck. I test fitted the new fenders without the running boards,and they were fine.What do I have? could someone give me the dimensions of the stock running boards.
07-19-2023, 01:31 AM | #2 |
Re: 54 running dimensions
Were the running boards modified for the wide fenders?
I've got a couple of of left running boards (two left, no right) out here that I can measure one of in the morning. If need be I can take one down to you or we can figure out how to get it to you for show and tell.
07-19-2023, 09:08 AM | #3 | |
07-19-2023, 09:48 AM | #4 |
62 1/2 inches:
My belief is there are only 3 sizes: regular shortbox, long box and flatdeck |
07-19-2023, 11:52 AM | #5 |
wasn't your truck assembled not that long ago? what changed, rear fenders? without going through your build thread I cant remember other than it looked pretty good before.
did the shop say where they didn't fit? too long, too short, not fitting the angle at the rear fender? |
07-19-2023, 08:55 PM | #6 | |
07-20-2023, 12:55 AM | #7 |
Straight down the top of the back I get Pretty close to that 62-1/2 that Lee green got.
The second shot is the distance from the back to the bracket that the running board bolts go in. it is straight on about 1/4 inch down the slot for the bolt. df Next is the board it's self. We can figure out how to get that down to you if you need it either having somone coming this way pick it up and haul it back or I can take a run down there. Worse case, I'll pull the running boards off the 48 and take them down. I'm using long bed boards when I stretch the cab.
07-20-2023, 09:53 PM | #8 | |
07-21-2023, 06:42 PM | #9 |
OK pictures usually tell a better story.
07-22-2023, 08:44 PM | #10 |
Here are a couple pictures
07-23-2023, 01:12 AM | #11 |
I'd say someone cut the corner off to fit the older 2" wider fenders and reshaped the edge:
Putting a corner back on it would not be much harder than taking the corner off was. Rest of the board looks great |
07-23-2023, 10:50 AM | #12 |
since the old boards are already in good shape but simply need the extra piece added I would just fab a new part shaped to fit and weld it on there. probably easier than prepping an old set that needs de-rusting etc. you could buy a new set too i guess.
07-23-2023, 03:04 PM | #13 |
Using my rusty old yard sale framing square it shows that the tip of the outside edge of the running board is 2-3/4 inches out from the end of the top back side of the running board.
It's probably more prudent to take a cut disk/saw and cut just the end plate loose so that you can shape that back out to the fender and make a patch to fill the space. If you have a profile gauge you can get the proper profile off the fender. That may be the least amount of work in the long run. Then it is just the finish work after weldig in the patch and prep and paint. Mine will need to be stripped before the get nice paint on them. In other news, it is hot here and the mountain is out in the sunshine today. Mt Adams that is west of me and NW of Hogfarm.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 07-23-2023 at 03:13 PM. |
07-23-2023, 05:29 PM | #14 |
Probably what I would do as well. If the rest of the board is in good shape just reshape the end that's not right.
07-23-2023, 09:29 PM | #15 |
it's pretty clear to see what happened now. I wanted to narrow my truck 2" on each side. It has turned into a very expensive and labor intensive project.But I sure like the way it looks. I still need to repair the cross member. Next week when my friend gets back from vacation, we plan on putting truck on his lift, we have a plan, not hard to fix. But I will make sure it never breaks again. I have added a lot of HP. I will be able to look under the running boards and see what was done, but that can wait until winter, need to drive it a few times this summer. And all my other projects, building a cabin on my property, hauling two dump truck loads of saw logs each day, then mill the lumber. How did I ever have time to go to work.
And thanks everyone for all the info,you guys make my life easy |
