07-27-2023, 03:20 PM | #1 |
Brake fluid
New brake system...front to back...left to right... on a 70 GMC. 4 drums if it matters. Im an old guy, always used Dot-3. Went to my local auto parts store. No plain old Dot-3. For all intents, only synthetics. Didn't buy any. Hope someone can educate me on the new stuff.
Thanks much...Don. |
07-27-2023, 03:40 PM | #2 |
Re: Brake fluid
This motul is my go to:
https://www.amazon.com/gp/product/B07KYWH2W8/ I used to use a Bosch 5.1 but my friends with track cars prefer the Motul... |
07-27-2023, 03:56 PM | #3 |
Re: Brake fluid
I just bought a quart of DOT-3 last Friday at WM.
07-27-2023, 05:27 PM | #4 |
Re: Brake fluid
I bought DOT 3 yesterday at Auto Zone. They've got DOT 4 also.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
07-27-2023, 07:59 PM | #5 |
Post Whore
Re: Brake fluid
It's your parts store . I bought a quart of DOT 3 today at NAPA.
But to your question this should help understand the differences. https://www.machinerylubrication.com...om%20the%20air. https://en.m.wikipedia.org/wiki/Brake_fluid
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-27-2023, 09:28 PM | #6 |
Re: Brake fluid
I used the O'Reilly Parts Store brand of DOT3 and it says synthetic on the label. It did not sway me one way or the other regarding choosing it to buy. If it says DOT3 it meets the required specifications and is suitable. I think it should be completely flushed out and replaced every couple of years just like coolant.
07-27-2023, 10:30 PM | #7 |
Re: Brake fluid
Is there a Tractor Supply nearby? This is what I have been using. DOT 3, not sure if it is synthetic or not, probably. I have had a hard time recently finding non-synthetic oils, so it seems I may be switching everything over soon, as I am not paying the same or more for a non-synthetic oil. $7 a quart.....same price at WalMart it seems.
https://www.tractorsupply.com/tsc/pr...fluid-32-fl-oz |
07-27-2023, 11:28 PM | #8 |
Re: Brake fluid
All the DOT3 at O'Reilly was synthetic
07-27-2023, 11:31 PM | #9 |
Re: Brake fluid
Anecdotally, it's all been synthetic for a long while:
https://bobistheoilguy.com/forums/th...thetic.158663/ Castrol and Valvoline make a DOT3&DOT4 if that helps Last edited by Rust_never_sleeps; 07-28-2023 at 01:28 PM. Reason: meets both standards, not a mixture of two types |
07-28-2023, 07:31 AM | #10 |
Re: Brake fluid
Store did have bottles of dot-3/dot-4. Wasn't sure it was what I wanted.
Thanks all...much appreciated...Don. |
07-28-2023, 09:13 AM | #11 | |
Re: Brake fluid
07-28-2023, 01:20 PM | #12 | |
Re: Brake fluid
Thanks for the tip, because I am getting ready to 100% bleed my brakes, even though it's only been 10-15 years. And, now for something completely confusing...
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
07-28-2023, 01:24 PM | #13 |
Re: Brake fluid
Oh yeah, how much fluid should I need to completely flush the system? 69 C10, GM square body discs, rear drums.
07-28-2023, 01:29 PM | #14 |
Re: Brake fluid
07-28-2023, 01:57 PM | #15 |
Re: Brake fluid
I'd likely buy a couple qts, maybe 3 to be safe, and it is always good to have some around, just keep in sealed container, as it should not go bad, until exposed to moisture in the air. Brake fluid attracts moisture if not sealed. Or at least that used to be the case.
07-28-2023, 03:50 PM | #16 |
Re: Brake fluid
07-28-2023, 05:11 PM | #17 |
Re: Brake fluid
Thanks, guys.
As they say in Texas, I'm fixin' to start thinkin' about doin' it.
07-29-2023, 12:46 PM | #18 |
Re: Brake fluid
One of the guys over on BobIsTheOilGuy said this when I asked about using DOT 5.1:
"I’m kinda hesitant using a DOT 4LV/5.1(ATE SL6/Super DOT 5.1, Bosch ESI6 or any of the OE-spec LV fluids) if your brake hydraulics aren’t all new, you never know of the lower viscosity fluid might seep out of old seals." Others also recommened AC Delco or Motorcraft DOT 3.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 07-30-2023 at 12:04 PM. |
07-30-2023, 12:11 AM | #19 | |
Re: Brake fluid
Parts that had Dot 3 running through them take Dot 3, though I believe Dot 4 will mix with them. Never mix DOT 5 or 5.1 with 3 or 4 simply because they don't mix. Downside of 3 and 4 are leaks that haven't been cleaned right away will damage all finishes. DOT 5 has it's fans, but after watching a video of someone running tests, to my knowledge it's not correct for the old stuff because the silicone expands and distorts the rubber.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-30-2023, 01:08 AM | #20 |
Re: Brake fluid
DOT 5.1 is glycol based and can be mixed with DOT 3 and DOT 4, although there is no need to mix any of these fluids with each other or think about mixing the fluids. It is easy and cheap to just mostly empty the reservoir in the master cylinder and put fresh of whatever fluid you want to use, and bleed about a quart of it through the system thoroughly to complete replace and refresh. So a newly-acquired truck where you don't know what fluid is in there should just be flushed and put the good ol' DOT 3 (labeled synthetic or not) in it and be done. If you ever have a leak or need to replace a part such as a cylinder or caliper or tubing, or even brake pads or shoes, it's time to repeat the full flush and change on the whole system, no reason not to do it. On a 67-72 truck there is no need to consider using anything other than DOT 3. If it's kept fresh, it's not going to boil or break down or give any problems. Just my opinion.
07-30-2023, 07:29 AM | #21 | |
Re: Brake fluid
07-30-2023, 01:27 PM | #22 |
Re: Brake fluid
Thank you
