07-30-2023, 04:00 PM | #1 |
Starters
1970 GMC BB TH400. C2500 if it matters.
It's been sitting for a good many years. Decided I'd clean up the electrical connections on the starter while I was down that way. Ran into a few issues. 1 - All 3 wires near the starter should be R&Red due to dry rot. Batt cable is a no brainer. The yellow wire will not be replaced as I have HEI. Anyone know the gauge of the purple wire? Looks like 14ga to me but??? Just for grins, if I was replacing the yellow wire, what gauge? 2 - All 3 connections ended up rotating the stud of the solenoid. Time for a new solenoid or would you just snug them back down? 3 - Following the purple/yellow wire back to the firewall was covered in tape. Aint no easy way to get tape in many areas along the path. Suggestions appreciated. Thanks much...Don. |
07-30-2023, 06:34 PM | #2 |
Who Changed This?
Re: Starters
Purple is 12 ga, yellow is 20. Here's a wiring diagram.
07-31-2023, 02:13 PM | #3 |
Re: Starters
Thank you...Don.
