08-04-2023, 12:08 AM | #1 |
Orientation of drum brake adjuster bar
I have the front drum brakes open on the passenger side. It is for a 1969 C-10 1/2 ton pickup. This is a look at the pushing edge of the auto adjuster bar.
And this is the way it was oriented to push the star wheel. Is this incorrect and the auto adjuster bar is from the driver side brakes? I'm not sure if the indented edge is supposed to stick out like that, or stick in towards the star wheel. If I had to guess it seems logical the indented edge of the adjuster bar would be sticking in toward the teeth of the star wheel that it's pushing down against. |
08-04-2023, 12:23 AM | #2 |
Re: Orientation of drum brake adjuster bar
One would think so, but the orientation is correct in the pic
08-04-2023, 01:38 PM | #3 |
The levers should be stamped L or R respectively.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-04-2023, 02:58 PM | #4 |
Tony that's one of my favorite pics on this site - it takes time to document something with that level of detail and you've built a gold mine of really helpful documentation over the years - thank you
08-04-2023, 04:36 PM | #5 |
Who Changed This?
I've never heard a front brake shoe called a "slipper", it's the primary shoe.
08-04-2023, 08:17 PM | #6 |
Thanks, good info.
08-04-2023, 10:52 PM | #7 |
Location: Herculaneum MO (20 minutes south of St. Louis
He's not talking about the brake shoe. It's literally labeling his right slipper.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
08-04-2023, 10:54 PM | #8 |
that's funny right there!
08-05-2023, 09:12 AM | #9 | |
Who Changed This?
08-05-2023, 11:07 AM | #10 |
My auto adjust bar is the same way . I've wondered before if it was backwards . Thanks !
08-05-2023, 07:46 PM | #11 |
What is the do-dad called that is in the center top that the guide plate and springs fit onto and that the shoes fit up against, and it also screws into the backing plate and spindle? I am parting out assemblies and I know some folks need those every now and then when they break. Are they the same part in front and rear?
08-05-2023, 08:14 PM | #12 |
I found out, it is the anchor pin. Is it different between front and rear? Still looking for that answer. Thanks.
08-07-2023, 08:08 PM | #13 |
Thank you Jocko. Couldn't have done it without encyclopedias like yourself.
08-07-2023, 08:22 PM | #14 |
Who Changed This?
The length of the anchor pin will depend on the width of the shoes, and on the offset of the backing plate. Not certain about trucks, but from sedan to wagon, the backing plates are different on vehicles because the wagons would have wider shoes on the rear brakes, generally the same as the front brakes. I'm talking about '60s in general, with all 4 wheels as drum brakes.
Tags |
auto adjuster, drum brakes, star wheel |
