Old 08-07-2023, 04:28 PM   #1
vjjack04
vjjack04's Avatar
72 Two Wheel Drive Blazer - New project
Folks,
I have not been on this forum for a while, ever since I sold my 55 Chevy truck a few years ago. I've been on Corvette Forum and the HAMB a little bit, but now back here so I can discuss ideas, problems and solutions with you guys, on this 1972 Chevy 2WD Blazer. Oh, its not mine, but I am going to get it running and do a few other things over the next coule of weeks.
vjjack04 is offline   Reply With Quote
Old 08-07-2023, 07:00 PM   #2
72gmguy
72gmguy's Avatar
Re: 72 Two Wheel Drive Blazer - New project
Looks nice! Good luck with getting it back on the road!
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 08-08-2023, 12:06 PM   #3
vjjack04
vjjack04's Avatar
72gmguy,
Thanks. My first hurdle is the starter. It was all goofed up and would only hit the flywheel for a bit then "zinng". Its a SBC so I figured easy to shim...not so much. Then new starter....however the problem isn't up or down (for shims) it needs to move towards the motor. Gap from the starter armature shaft to the flywheel is about a 1/16+ wider than it should be. Flywheel is 168 tooth. I gotta figure this out first, then it might run.
Old 08-09-2023, 09:06 PM   #4
BIG ORANGE
BIG ORANGE's Avatar
Buy a lil mini starter like the racecar guys run, I put them on my blazer, the parts house starters are junk. Nice looking blazer, best of luck, I'm sure someone else will have more input to help out....
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 08-22-2023, 11:19 AM   #5
vjjack04
vjjack04's Avatar
Guys,
Trying to figure out wiring on this 72 Blazer I am working on. Trying to figure out what is what on bulkhead connector. I have looked at the schematic, but still confused. Here's what I am working with (see drawing). This is a replacement M&H bulkhead connector. Are the labels I have so far correct? Can one of you give me details on the rest or any other useful info? Thanks.
