Old 08-11-2023, 01:58 PM   #1
tim71
tim71's Avatar
Wierd Brake Issue
My 72 Blazer build is 98% done but I've got a brake issue. If you stop in a normal manner without heavy braking the brakes operate normally. However, if you stop hard or even push pedal hard while stopped, the brakes will momentarily (2-3 seconds) stick and hold the Blazer then release. If you are going 50 mph and apply hard brakes and release at say 30 mph they will also stick and then release after a couple seconds. When they release you can feel a small thud thru the brake pedal.
Every brake component is new except for the front rubber brake hoses from frame to caliper. The brake pedal and linkage to the booster seem to be operating correctly. I'm not to anxious to change these hoses because I don't want brake fluid everywhere. Seems to me that if the front hoses were bad, they would not release at all and cause the brakes to drag. As a test, I also put a washer between the mc and booster to see if that rod was to long.
Any ideas?
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 08-15-2023, 02:30 PM   #2
biketopia
Re: Wierd Brake Issue
I would start with front hoses..they fail internally and will act as a one way check valve. Is this a disc front drum rear?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 08-16-2023, 06:16 PM   #3
cadillac_al
I just replaced a couple of brake hoses on my Chevy motorhome. They were acting up intermittently for a couple years until they started making the brakes drag all the time. I should have replaced them the first time I suspected them.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-24-2024, 10:46 PM   #4
c30
Junior Member
c30's Avatar
Absolutely, it's the hoses. I have a 67 c30 with drums that was braking like that. Went to bleed the brakes and it actually took a little foot pressure to get the fluid to come out.
I had heard about old brake hoses collapsing and these were probably original to 1967.
I replaced all three and once I started bleeding them I could tell, right away, that this was the issue.
c30 is offline   Reply With Quote
