Old 08-12-2023, 04:10 PM   #1
dmjlambert
dmjlambert's Avatar
Manual master cylinder, distribution block, and bracket for drum/drum
Here is a manual brake master cylinder and distribution block and bracket for front and rear drum brakes, offered up here for cheap. If this stuff will keep your truck on the road, I would be delighted to hear that. I removed this from my 1969 CST/10 1/2 ton pickup. The master cylinder is from about 2015 and was in working condition when I changed to a disc brake system last year. It has a deep pushrod hole as you find on master cylinders that are made for manual brakes. The distribution block is original from 1969. I also have in the picture a brass brake line adapter that somebody may be interested in. Please see prices and add shipping, or pick up in Cypress TX (near Tomball, this is northwest of Houston, folks). If I had to guess I would think the master cylinder will ship for between $15 and $30. I will find out shipping for you if you have interest, let me know your city and zip code. The distribution block should fit in the smallest flat rate box for about $10.40 if I don't send the brake lines with it.
Manual drum/drum brakes master cylinder $3
Distribution block $3
Distribution block bracket $1
Brass brake line adapter $0
Any of the pictured brake lines $0
dmjlambert is offline   Reply With Quote
Old 09-09-2023, 01:05 AM   #2
dmjlambert
dmjlambert's Avatar
Re: Manual master cylinder, distribution block, and bracket for drum/drum
ttt
Old 09-11-2023, 08:52 AM   #3
SidsChopShop
Are the brake lines factory bends?
SidsChopShop is offline   Reply With Quote
Old 09-11-2023, 08:58 AM   #4
dmjlambert
dmjlambert's Avatar
I believe the one on the right for the rear brakes is original. The other 2 are for the front brakes and they are from the local parts store and bent by me.
Old 10-11-2023, 11:59 AM   #5
dmjlambert
dmjlambert's Avatar
ttt
brakes, distribution block, master cylinder
