6? K10
I have a question about rebuilding an old Chevy truck. A couple of years ago a young girl ran a stop sign on the highway in front of me and my 71 K10 was totaled (frame bent/cab pillars bowed out/steering locked). I kept the truck as part of the insurance settlement. I just looked at a mid 60's K10 (think it is a 65 or 66) but missing the engine. Owner said it had a straight 6 in it previously. It shouldn't be to bad to move the 350 from the 71 to the older truck. The thing I am not sure about is just swapping the engine or swapping the entire drivetrain over? From what I remember, the old 420 transmission and the Rockwell transfer cases were pretty rough. How much trouble would the swap be? A plus is that I would have the power steering pump and gear, brake booster, and whatever else I could salvage from the 71 to use on the other truck. Thanks for your help.
![]() ![]() Join Date: Oct 2014
Re: 6? K10
Welcome to the forum. I'm going to move your thread to the appropriate area. The guys and gals there will probably have more answers for you.
#3 | |
Re: 6? K10
If your dream is to have a 60-66 body on your running gear, you should find a 2wd and graft the body on your frame, but be aware there will still be fiddly fab work and it will never be as “right”. Also you will not be messing with a fairly rare 60-66 factory 4x4 that someone could just drop an engine in and go. Good luck with whatever you decide Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
![]() ![]() ![]() Join Date: Jan 2018
Re: 6? K10
If the truck you looked at had a 250 inline 6, then your 350 will bolt up just fine to the sm420. If it had a 292 inline 6, you'll have to change out the passenger side frame stand that sat further forward on the frame.
I haven't messed with the 4wd trucks, but if you take the transmission and transfer case mounts from your 71, my guess is it would probably be fairly easy to swap out the entire drivetrain
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Re: 6? K10
Oops,
Sorry, just reread your post and noticed the frame is bent. That changes things. While putting your old engine in will be a slam dunk, swapping out all the rest of the running gear will take some fab work, and again, it will never be as “right”, but that’s a personal decision. As far as the transmission goes I have driven many of both types and would personally take a 420 over a 465 any day, but I know others will argue that point. If the 221 is in good shape I would just leave it. Bearings and gaskets are not that big a deal if needed and the divorced setup is easier to work on because you don’t have to drop the transmission. If the gears are toast then parts can be difficult. It also runs louder. Driveline angles are better though, because the outputs are lower, that’s why earlier trucks ride higher. Unless you’re out doing stupid stuff either case with last just fine Hope this helps
#6 | |
Re: 6? K10
As far as the trans/transfer mounts go they are very different. Take a good look at both side by side and you will see it’s definitely not a bolt in. You will have to evaluate your fabrication skills.
#7 | |
Re: 6? K10
Re: 6? K10
The rear motor mount under the bellhousing are the same from 63 to 72. You shouldn't have to change that crossmember if you swap engine bellhousing, trans and transfer. You will have to change the crossmember under the transfer case. The bolt holes may or may not be in the right place.
The OD on the bearing retainer for the 465 should be a bit larger than the bearing retainer for the 420. That is the main difference in cast iron V8 bellhousings. In truth if you have all the V8 pieces sorted out and ready to use, and have done the homework on front engine mounts you should be able to roll the truck in the garage, pull the six, stab the V8 and pretty well have it ready to drive away by the end the day. Prep and planning ahead of time helps a lot though.
