Finding correct fuel pump
Not sure this is the right sub group but it fits my truck the closest
My truck is a 1988 K30 Cab & Chassis with SBC & carburetor. It’s original from the factory with the SPID showing carburetor. The fuel pump is mounted on the block with three lines - in, out & return lines. My problem is I can’t find the correct fuel pump with the rubber line connections in the correct location for my truck - all the parts stores wanna sell me a pump for the tank…. Any help?
Restomod 1970 2WD Blazer LT4 Custom 1968 Suburban Cummins |
Re: Finding correct fuel pump
Ask for an ‘86 year or older pump.
Have you tried looking at pictures of fuel pumps for other models and years on rock auto?
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
Check out 1983 C10 5.0L or 5.7L, three lines. two barbed one threaded.
Your fuel pump has a number stamped on it. Find that number and get a new one.
1988 “squarebody” should be a V30, instead of k30. This should allow them the option of the tbi or 4bbl engine.
Just got on Autozone’s website and it does |
![]() Join Date: Feb 2000
This is what RockAuto lists for a 1988 V30
https://www.rockauto.com/en/moreinfo...t=6256&jsn=502
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
![]() Join Date: Oct 2013
Just an option, went through fuel pump issues with 1986 K10, installing new GM HO 350. New pump kept leaking down, losing prime after a day. Went through two none USA made, before solution. Purchased an old NOS AC Delco made in USA fuel pump, no more problem. This just my case. However, suggestion for solution came from repair shop. Now have several USA made AC Delco fuel pumps.
