09-05-2023, 03:31 PM | #1 |
63 w/14 gal Mustang Tank
Hey guys, I picked up a 14 gall Mustang tank the other day.
I have just the cab sitting in the frame with suspension and rear differential installed. I know I will need to trim the frame rails , but how far forward from the rear of frame rails does the tank get mounted? Thanks in advance for any input |
09-06-2023, 01:56 PM | #2 |
Re: 63 w/14 gal Mustang Tank
Anyone?
09-06-2023, 10:43 PM | #3 |
I didn't use the Mustang tank. I used a Tanks Inc one and I put it as far forward as I could.
09-08-2023, 01:27 AM | #4 |
I mounted that same tank in my truck up to the cross brace. on the short bed there is just enough room. I don't have a good picture to show.
09-08-2023, 08:18 AM | #5 |
What I’m hearing is mount it as far forward as possible?
09-08-2023, 03:38 PM | #6 |
It took up all the space on mine. I don't think you will have a choice.
09-13-2023, 03:29 PM | #7 |
I'm running the Mustang tank I bought from Tanks Inc. I tucked it in under the top of the frame.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
09-13-2023, 05:10 PM | #8 |
Thanks! I try that too. Did you figure out what to do about the sending unit to make it work with our factory fuel gauge?
09-20-2023, 01:05 PM | #9 |
I can't help you there. I've got aftermarket gauges so I just ordered a gauge to match the Mustang sender.
09-21-2023, 01:25 PM | #10 | |
https://67-72chevytrucks.com/vboard/...d.php?t=447185 |
09-24-2023, 01:17 AM | #11 |
I got mine from tanks Inc. it works with stock gauges.
09-24-2023, 05:48 PM | #12 |
10-01-2023, 11:14 AM | #13 |
I did cut the top frame rail back about 1/2 inch on each side.
