09-07-2023, 07:27 AM | #1 |
Accelerator Pedal Bracket
Anyone know where I can find the bracket that holds the accelerator Pedal rod to the mount that holds it to the firewall? Not exactly sure what it's called but I have attached a pic to show what I mean. Appreciate any help I can get. Thanks.
09-07-2023, 08:00 AM | #2 |
Re: Accelerator Pedal Bracket
GM calls that metal plate a reinforcement-accelerator rod support, GR 3.452 part number 6261803.
The plastic part is 3993087. Your sources are NOS or good used for the support.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
09-08-2023, 03:06 PM | #3 |
I found one in a junk yard on a late 70's early 80's blazer. It had some brackets on the one side. I cut the bracket off and used the triangle piece after I painted it. I would assume the full size pickups of these years would work also.
