Old 09-09-2023, 12:24 AM   #1
vardenafil
parking brake cable recomendation
for those of you who have done rear disc conversions using the caddy e brake calipers... what length brake cable did you use? I measured roughly 50 inches from the caliper to the cable hanger clip on the frame. is there a specific type cable that works better?
vardenafil is offline   Reply With Quote
Old 09-13-2023, 09:33 AM   #2
Custom 68
Custom 68's Avatar
Re: parking brake cable recomendation
I will jump in here too for information. My rear brake is the Camaro kit offered on here.
I don't want to hijack this thread but maybe it is the same info?
I am sure somebody has done this and completed the final piece.
Thanks,
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-15-2023, 12:52 PM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
When I did the rear c5 brakes swap on my truck, I looked on rock auto, bought the oem cables for the caliper application and shortened them myself to fit the stock c-10 intermediate cable, then sent the cables off to i believe it was https://push-pull.com/custom-cables-brakes/
and they simply put a new crimped on end for the cable. while its not off the shelf, it was cheap and a very simple solution.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 10-16-2023, 04:38 PM   #4
SteveL66
Collecting the parts right now for my setup and have the Cadillac calipers on my 66. Info I found on POL was that the cable housing length is 34.7” and cable length is 43.6” for the conversion cables. The part number on POL is EBC6387X, 2 cables are $103 so I am still looking for another option. Dimension of the cables that were on my truck are housing 30.5” and cable is 40.25”. They are just a couple inches too short for me to hook to the caliper.
SteveL66 is offline   Reply With Quote
Old 12-16-2023, 08:22 AM   #5
dennislbrooks
dennislbrooks's Avatar
On my 67 with a 9.5 14 bolt I used Camaro rear disc. I used the Camaro cables from Rock auto. Placed/fitted the frame mount then used the cable couplings from Rockauto. If I had to do again I would just leave the drums. But for the intermediate cable I used 1/8 inch stranded cable (TSC), drilled an eighth inch hole in about 1/2 inch length of 5/16 inch solid rod. Squeeze them with a crimp tool then put a hot mig spot on the ends.
Turned my orig emergency brake into a parking brake. To pass Texas inspection I had to depress brake pedal then apply hand brake lever to pass in gear idle.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
