09-16-2023, 06:40 PM | #1 |
Gas tank help
I found the P/O ( probably my dad), left an access to the fuel sender it’d not the typical I was expecting to find someone in this group had an idea at least before pull it perhaps damaging it on the process
09-16-2023, 06:42 PM | #2 |
Re: Gas tank help
A second picture
09-16-2023, 10:19 PM | #3 | |
Post Whore
Re: Gas tank help
Is this a driver or a longer term project? If it is a driver I would have some gasket material handy and tools to make a new gasket. Either way it is likely you will need a new gasket for reassembly. If you have time you may find that the gasket is a common one. Other than that I recommend blowing all dirt and debris away followed by scrubbing with soap and water to clean it as well as possible. Getting it nice and clean around the sender will prevent any debris from getting into the tank when you pull it.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-16-2023, 10:38 PM | #4 |
Re: Gas tank help
Thanx I’ve never seen a sender with 3 tubes, I know one is main feed, and he is for the vent, I don’t know about the last one even though it’s capped
09-16-2023, 10:53 PM | #5 |
Post Whore
Re: Gas tank help
It being an aftermarket tank it may have enough ports to be legally installed in California back in the day. That would have meant it would have had to tie into the emissions system.
So one supply to fuel pump, one return from fuel pump and one vent line to the vent canister.
09-16-2023, 10:56 PM | #6 |
Re: Gas tank help
I never even thought about a charcoal canister
See I knew someone would School me |
10-05-2023, 04:38 PM | #7 |
Re: Gas tank help
I have a dealer installed tank on mine with the universal five screw. I ended up keeping the pickup and flange. I bought 0-90 ohm universal sending unit on amazon for cheap. It took some garage engineering, but I got it hooked up. It may not be the most accurate, but it reads about 7/8 when full and 1/4 when empty.
Pics are the before, after, and gauge. |
