10-06-2023, 08:12 PM | #1 |
Anyone Ever Bent Their Trans Dipstick Tub
Hey Guys,
I Have an 80 Jimmy with a 350/350 & replacing the factory under spark plug exhaust manifolds to the earlier rams horn over the spark plug exhaust manifolds. I will be routing the spark plug wires to the back of the block & under the manifolds. My only issue is getting around / over the transmission dipstick tube. Not sure if they made a different tube on earlier models to go with that setup or bending it is my only option. Please way in if you have done something like this or have any suggestions. Thanks Scott |
10-06-2023, 08:16 PM | #2 |
Re: Anyone Ever Bent Their Trans Dipstick Tub
Here is a pic of what I’m working on. You can see the black spark plug bracket and the position in relation to the dipstick tube. The way it is now, not gonna happen.
10-06-2023, 08:45 PM | #3 |
1 more
10-07-2023, 08:01 PM | #4 |
I have tried and ended up kinking it bad enough to have to buy a new one.
Can you rotate it to a better position? |
10-07-2023, 10:50 PM | #5 |
I would look at making a custom spark plug bracket over risking ruining a trans filler tube. Or look at mounting the 4 wire loom vertically facing the firewall so the wires go behind the filler tube.
10-08-2023, 12:34 AM | #6 |
Post Whore
not the trans, but i tried bending my oil dipstick to clear headers, it broke
i wound up using a Lokar flexible on it, they also make them for the trans...you might look into that
10-08-2023, 08:12 AM | #7 |
Half of my trucks have a shorter dipstick tube, probably from a car. That would be my solution. I bought an aftermarket dipstick tube for my car that seems to work pretty well, doesn't leak.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
10-08-2023, 09:26 PM | #8 |
Thanks for the input & suggestions! I'm headed to a local junk yard here in a few days. Ill look for a shorter version.
Scott |
10-09-2023, 12:57 AM | #9 |
Yes It will break if bent.
Consider installing a spacer between the tube attachment point and the back of the block. If you have the room you might be able to go in front of the tube that way. Difficult to ascertain how much room you have before the tube impacts the cowl. Cheers |
10-10-2023, 11:17 AM | #10 |
I've bent them before --ever so slightly by using an electricians conduit bender. but you have to remove the tube from the vehicle
10-14-2023, 10:57 PM | #11 |
BMW & ASE Master Certified
I bent a 6l80 tube with a tube bender to make it fit a little better. If you have the correct tube bender, then it will more than likely bend no problems. But if you don't have a bender, expect it to kink. If you have a 3d printer, you can print yourself the dies and make a home made bender for a few bucks. I made a set of 3d printed dies to bend some aluminum tubing for an a/c line project. I got the idea to 3d print a set of dies from youtube, these guys 3d printed dies to bend 1.5" steel tubing in a hydraulic tube bending machine... pretty cool
https://www.youtube.com/watch?v=R7y5MIux_uQ clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
