10-10-2023, 07:21 AM | #1 |
shifter does not line up
My column shifter does not match my trans. When I shift the trans from drive to reverse. The column stops short. I have to pull back and sift just a smidge past it for it to go into gear. Is there a fix for this?
thanks Chris
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
10-10-2023, 07:58 AM | #2 |
Re: shifter does not line up
If you look under the truck you will see the long rod that connects the column to the trans itself. There is a "barrel" that slips along that rod and is clamped with a bolt.
Loosen the bolt. Manually put the trans in N (under the truck) and then the shifter in N (in the cab) and then clamp the bolt back down (under the truck). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-10-2023, 08:03 AM | #3 |
Once you get the shifter and trans relationship where you want it: if you have to adjust the needle indicator that is done by sliding a clip on the bowl of the shifter base.
Remove the closeout panel on the dash and the cluster bezel. You should see a string operated Rube Goldberg device that moves the needle. At that point you should see the clip; move that clip to get the indication where you want it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-10-2023 at 09:49 AM. |
10-11-2023, 07:25 AM | #4 |
thank you
10-14-2023, 11:18 PM | #5 |
BMW & ASE Master Certified
there might also a plastic half sphere shaped washer that the rod pivots off of... my 87 has that part, a flat washer and a spring to keep some tension on that linkage so it pivots smoothly.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
