Reinforcing plate for master cylinder & steering column - What holds it on?
What holds this reinforcing plate/bracket to the firewall? Is it just the bolts or is it also welded?
Evan B. |
![]() Join Date: Mar 2003
Re: Reinforcing plate for master cylinder & steering column - What holds it on?
Spot welded to the wall
Thanks. I'll see how it looks cleaned up before deciding if it needs to come off.
Evan B. |
Why would you remove it? Factory put it there for a good reason.
It would get put back on. I'm cleaning up the firewall and addressing rust.
Evan B. |
It's going to have quite a few spot welds holding it
