10-12-2023, 10:27 PM | #1 |
firmer seat foam?
What options do I have for firming up my bench seat? The cover is nice and I replaced the foam last year with new foam from LMC. It's still too soft for my tastes. When I replaced the foam, I noticed all of the springs were in place and the wires were not broken. Is stiffer foam available? Can I change to stronger springs or more springs maybe? The shape of the seat and everything else is fine with me. I just want it to be stiffer. I'm only 160lbs and feel like I sink in when I sit down.
Thank you!
1986 C10. Stock aside from being dropped on 20's. |
10-13-2023, 11:35 PM | #2 | |
Re: firmer seat foam?
So when you had the seat completely torn down, you said the springs were in place and the grid wires weren’t broken. But were the springs snug? The grid and springs are supposed to be snug, not loose. On most, and I mean 99% of the seats I stripped to restore, the grid and springs were always loose. That is why the seat feels soft, that and the fact you’re using new foam. Like I said, I think they are too soft. One option, you can purchase a new grid and spring kit from USA1 Industries. I also put a layer of jute between the foam and grid. That helps support the foam a little, and it protects the foam from the grid wires digging into the foam. Here’s some pictures of when I restored my own personal bench seat for my truck. Although I had plenty of new foam that I could have used, I chose to use the original foam.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
10-14-2023, 10:32 PM | #3 |
I didn't check to see if they were loose or not. I didn't think about it honestly. I figured if everything was there and not broken, I was good. I guess not.
Is there a way to tight everything or can it only be replaced? Thank you.
10-14-2023, 10:49 PM | #4 |
Yeah it can be tightened. I did on all the seats I restored. Or I replaced the grid and springs with new. Either way, the seat would have to come back out and stripped back down to do any kind of repair.
10-14-2023, 10:54 PM | #5 |
Are there videos or instructions on tightening everything? In your experience, has tightening worked well or should I just replace? The parts are only $60 from USA1 so it's not a terrible expense.
Thank you
10-14-2023, 11:00 PM | #6 |
The only video I have made was just showing the loose springs, and then showing how snug they should be. I doubt thee are any other videos on how to tighten them, because most people don’t even realize it needs done.
