Old 10-13-2023, 02:03 AM   #1
DBear
DBear's Avatar
Steering Column Conversion?
Question:
I have a 78 manual tilt column, and a 78 non tilt automatic column. Using both columns, could I convert the automatic column to tilt with the parts from the manual column? Thanks in advance for any help you can provide.
DBear is offline   Reply With Quote
Old 10-14-2023, 07:37 PM   #2
Factory Guy
Factory Guy's Avatar
Re: Steering Column Conversion?
Yes i am sure you can if you have the tools and the knowledge. I found a used column then sent it out and had it professionally rebuilt, as i went from a standard column no cruise, no tilt to a Cruise/Tilt model. The professional shop helped with the wiring as a tilt and a non tilt are wired quite a bit different.
Factory Guy is offline   Reply With Quote
Old 10-16-2023, 07:28 AM   #3
chrismoore701
chrismoore701's Avatar
I used three columns both tilt and straight to make one tilt. Just dig in, but make sure you have the key parts for the tilt that work.
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 10-16-2023, 09:59 AM   #4
DBear
DBear's Avatar
I think I have found a nice auto tilt column to use, and will probably sell the manual tilt column to offset the cost of the one I am getting...if it all goes through LOL.
Old 10-18-2023, 12:53 AM   #5
1774btcrew
1774btcrew's Avatar
You cannot combine to make the automatic a tilt column. The lower bowl/shift lever housing is not a big enough diameter to allow the ball part of the tilt to pivot if that makes sense.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
