Old 11-05-2023, 07:25 PM   #1
ladybugblazer
Question Regarding Domelight Wiring
So I decided to start digging and finding out why my dome light wasn't working today. I took off the cover and found found that both the leads were hanging only with a few strands of wire and bundles of electric tape. After taking off the electric tape to see what was under I was greeted with the attached image. Not sure why there are 3 wires I labelled them 1, 2, and 3 in the picture. Two are yellow (1 & 2) and one is red (3). The two that are yellow (1 & 2) seem to be going to the back of the truck, and the one that is red (3) seems to be coming from under the headliner towards the front of the truck. Wires 2 & 3 get combined on one of the leads. Could it be possibly that this is to continue power to the back lights?
My plan was to cut off the two bad leads and crimp/heat shrink in two new ones that I already bought, but because there are three wires I need to figure out how to connect those 3. I don't wanna solder. I found this WAGO Connector of amazon and was thinking about using this:
https://www.amazon.com/Wago-221-413-...dp/B06XGYXVXR/
But I was just wondering if this is a good fix or if I am even doing this job right
ladybugblazer is offline   Reply With Quote
Old 11-20-2023, 04:24 AM   #2
cerial
cerial's Avatar
Re: Regarding Domelight Wiring
My guess is they are using that rear dome to power a rear view mirror light or some other additional light. Or they did at some point. Follow the red wire to see where it goes.
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 11-28-2023, 11:35 PM   #3
72 Cheyenne K20
Here is a pic of what the harness is supposed to look like. You only need the orange & white wires for the light bulb to fit into for it to work. Hope this helps
Scott
72 Cheyenne K20 is offline   Reply With Quote
electrical
