Old 11-14-2023, 11:07 PM   #1
chris mc bride
chris mc bride's Avatar
disc conversion
Hvae been looking at disc conversion for 1969 Panel truck. Noticing most say they are same thru 1987. I take that to mean .If I find a set off of any of those years it will bolt on. Correct or am I missing something?
Only the stupid know too much to learn something new.
chris mc bride is offline   Reply With Quote
Old 11-14-2023, 11:20 PM   #2
franken
Re: disc conversion
I've read that at least half ton front crossmembers can be swapped from 71 to some year as a way to get front disks. Don't forget the master cylinder and prop valve.
franken is offline   Reply With Quote
Old 11-18-2023, 08:53 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Re: disc conversion
The spindles have different tapers for the ball joints and tie rod ends. 63-70, 71-72, and 73-87 is the differences. Ball joints for all three tapers fit in stock 63-72 and 73-87 arms. Difference in arms is at the control arm bushings. Steel for 63-72, rubber for 73-87.
I’m using 73-87 ball joints in stock 63 control arms on my 63’s disc conversion
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
